ConBee II - Domoticz - Deconz, error: This device don't support action
Posted: Saturday 20 February 2021 11:12
Installed yesterday my new ConBee II USB and added the first Zigbee switch to it (Blitzwolf SHP13).
I can switch the outlet from the Phoscon web interface.
Next step was to add Zigbee to Domoticz (2020.2).
Installed Deconz plugin, generated API, added hardware and the SHP13 shows up. Even power figures show up.
The SHP13 was initially added as "Push On" button. I changed that to On/Off.
I can't switch the SHP13 from Domoticz. An error message appears in the log:
Googled on this error message but no real clues.
The SHP13 appeared as light in Phoscon. I expected that it would appear as switch.
I do not see a way to change that kind of detail in Phoscon. Is it correct that it is added as light?
I must have done something wrong but can't figure out what.
Anyone have a clue?
Thanks!!
Domoticz 2020.2 on a Raspberry Pi
ConBee II firmware 2.09.03 (26660700). Installed in a separate Raspberry Pi
Deconz plugin Domoticz version 1.0.16
2021-02-20 10:19:42.409 Status: User: admin initiated a switch command (1697/BWZ01 - test/Off)
2021-02-20 10:19:42.427 Error: (Deconz 192.168.178.143) This device don't support actionThe SHP13 appeared as light in Phoscon. I expected that it would appear as switch.
Anyone have a clue?
Thanks!!
