Is there a type of power switch wich is, out of the box compatible , with domoticz ( on mij synology NAS) , preferable with power meter.
I don't want to flash the device....
any advice is welcome
Compatible wifi smart switch with power metering
- Domoticz version: 2025.1
Re: Compatible wifi smart switch with power metering
You could try tp-link HS100/HS110 smartplug with plugin https://github.com/lordzurp/domoticz-tplink-smartplug/
Edit: Also Shelly has smart plugs that can be controlled with the Shelly MQTT plugin (a little bit more work because you have to setup MQTT on your server)
https://github.com/enesbcs/Shelly_MQTT
