Page 1 of 2
Daikin airco makes Domoticz crash
Posted: Wednesday 17 February 2021 21:56
by Bospieper
I have hopefully a small problem regarding the use of a Daikin airco with Dzvents. The airco is on our bedroom and is active between 22.45 and 07.00
When active the program looks at the bedroom temperature, when above 19 degrees Celsius the airco start cooling until the temperature is below 18 degrees. The problem is when the airco at 22.45 becomes active soon after that Domoticz crashes. Sometimes whitin 10 minutes, sometimes after hours. There's not a pattern in the crashes. When I stop the Daikin plugin and the script in Dzvents then Domoticz works as it should be so it's pretty sure that the problem is the plugin or the script. The plugin is the latest version. Here's the script:
timer = {
'between 22:45 and 07:00',
'between 07:00 and 22:45'
logging = {
level = domoticz.LOG_ERROR,
marker = 'Daikin airco',
execute = function(dz, timer)
local airco = dz.devices('Slaapkamer - airco on/off')
local fan = dz.devices('Slaapkamer - airco Fan Rate')
local temp = dz.devices('Slaapkamer - airco Temp IN')
if dz.time.matchesRule('between 22:45 and 07:00') then
if temp.temperature >= 19 then
airco.switchOn()
fan.setLevel(20)
dz.log('Airco staat aan', dz.LOG_INFO)
if temp.temperature < 18 then
airco.switchOff().checkFirst()
dz.log('Temperatuur is onder de 19 graden', dz.LOG_INFO)
elseif dz.time.matchesRule('between 07:00 and 22:45') then
airco.switchOff()
Re: Daikin airco makes Domoticz crash
Posted: Wednesday 17 February 2021 22:45
by waaren
Bospieper wrote: Wednesday 17 February 2021 21:56
When active the program looks at the bedroom temperature, when above 19 degrees Celsius the airco start cooling until the temperature is below 18 degrees. The problem is when the airco at 22.45 becomes active soon after that Domoticz crashes. Sometimes within 10 minutes, sometimes after hours. There's not a pattern in the crashes. When I stop the Daikin plugin and the script in dzVents then Domoticz works as it should be so it's pretty sure that the problem is the plugin or the script. The plugin is the latest version. Here's the script:
Do you have the domoticz log from just before the crash?
If you replace the script with the version below it will show some extra info in the log.
return
on =
timer =
'every minute',
logging =
level = domoticz.LOG_DEBUG,
execute = function(dz)
if dz.time.matchesRule('at 22:45-07:00') then
airco.switchOn().checkFirst()
if fan.level ~= 20 then fan.setLevel(20) end
elseif temp.temperature < 18 then
You can start logging to disk using below procedure
The domoticz logfile location and other settings are defined in /etc/init.d/domoticz.sh
the relevant settings are in the DAEMON_ARGS var.
with an editor of choice
DAEMON_ARGS="$DAEMON_ARGS -log /var/log/domoticz.log" # or any other OS file
#DAEMON_ARGS="$DAEMON_ARGS -loglevel normal,status,error, debug" # debug disabled for now
DAEMON_ARGS="$DAEMON_ARGS -loglevel normal,status,error" # these loglevels will make it to the logfile
#DAEMON_ARGS="$DAEMON_ARGS -debuglevel normal,hardware,received,webserver,eventsystem,python,thread_id"
sudo systemctl daemon-reload
sudo service domoticz stop
sudo service domoticz start
sudo tail -f /var/log/domoticz.log
Posted: Thursday 18 February 2021 7:22
by Bospieper
Thanx Waaren,I've made the modifications and come back to you with some logfiles.
Posted: Thursday 18 February 2021 15:53
by Bospieper
Hi Waaren, this morning Domoticz freezes. I've copied the relevant data in to a word document so the file size is not exceeding the 400 kb.
Gr. Piet
Posted: Thursday 18 February 2021 16:33
by waaren
Bospieper wrote: Thursday 18 February 2021 15:53
Gr. Piet
I see in this log that the crash started at 12:14:31
The dzVents script starts every minute on the minute so I guess we can rule that one out.
But from this log I cannot tell what triggered it. Do you have something in the log from the minute before this hang?
It could also be helpful to see what is send from your airco to domoticz. If it is send via MQTT you can inspect what is send with
mosquitto_sub -F "%U - %t - %p" -v -p 1883 -t "#"
Posted: Thursday 18 February 2021 18:20
by Bospieper
I've made a lager selection in time, strange thing is in the log. There is a gap in time between 12:23 and 12:39 as you can see.
I send you the MOTT asap.
Posted: Thursday 18 February 2021 18:24
by waaren
Bospieper wrote: Thursday 18 February 2021 18:20
There seems to be a dzVents script blocked. From this log I cannot see if this is the cause or a result of the hang.
Can you please switch on dzVents debug mode in the settings ?
Posted: Thursday 18 February 2021 19:47
by Bospieper
Hi Waaren, the only MOTT client who's exchange data with Domoticz is my EMS/ESP module for my heatpump. ( see attachment)
Posted: Thursday 18 February 2021 20:16
by Bospieper
Hi Waaren, the logfile from the moment Debug is active
Posted: Thursday 18 February 2021 20:18
by waaren
Bospieper wrote: Thursday 18 February 2021 19:47
Ok lets see what the dzVents debug shows just before a domoticz hang.
Posted: Thursday 18 February 2021 20:28
by Bospieper
I let you know
Posted: Friday 19 February 2021 19:33
by Bospieper
Well it freezes at 11.31. I'll send you logfile from 11.00 when everything was normal.
Posted: Friday 19 February 2021 21:01
by waaren
Bospieper wrote: Friday 19 February 2021 19:33
I see a couple of strange things (in the P1 area and pluginmgr) but cannot pinpoint it to one particular cause.
You first could try to switch on full domoticz debug.
in /etc/init.d/domoticz.sh (see earlier post for procedure)
DAEMON_ARGS="$DAEMON_ARGS -loglevel normal,status,error, debug" # debug enabled
# DAEMON_ARGS="$DAEMON_ARGS -loglevel normal,status,error" # these loglevels will make it to the logfile
Please note this will produce a sh#$%$ load of logmessages but it might show some useful information. If that does not lead to a clear insight what happens, the only other way forward I can advise here is to switch off all Python plugins, dzVents, Blockly and classic Lua scripts and if that will lead to a system without freezes start them one after the other until the freeze hits you again. I understand it is not a nice approach but I don't know how to get to the bottom of this in another way.
Posted: Friday 19 February 2021 21:19
by Bospieper
Hi Waaren,
I've made the adjustments as earlier stated. I thought that is what in the domoticz.log appears. Is there another logfile I should send to you?
Posted: Friday 19 February 2021 21:23
by Bospieper
- Spoiler: show
#! /bin/sh
### BEGIN INIT INFO
# Provides: domoticz
# Required-Start: $network $remote_fs $syslog
# Required-Stop: $network $remote_fs $syslog
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Home Automation System
# Description: This daemon will start the Domoticz Home Automation System
### END INIT INFO
# Do NOT "set -e"
PATH=/sbin:/bin:/usr/sbin:/usr/bin:/usr/local/bin
DESC="Domoticz Home Automation System"
NAME=domoticz
USERNAME=pi
PIDFILE=/var/run/$NAME.pid
SCRIPTNAME=/etc/init.d/$NAME
DAEMON=/home/pi/domoticz/$NAME
DAEMON_ARGS="-daemon"
#DAEMON_ARGS="$DAEMON_ARGS -daemonname $NAME -pidfile $PIDFILE"
DAEMON_ARGS="$DAEMON_ARGS -www 8080"
DAEMON_ARGS="$DAEMON_ARGS -sslwww 443"
#DAEMON_ARGS="$DAEMON_ARGS -log /tmp/domoticz.txt"
#DAEMON_ARGS="$DAEMON_ARGS -syslog"
#DAEMON_ARGS="DAEMON_ARGS -debuglevel normal, hardware,received,webserver,eventsystem,python,thread_id"
# Exit if the package is not installed
[ -x "$DAEMON" ] || exit 0
Posted: Friday 19 February 2021 22:19
by waaren
Bospieper wrote: Friday 19 February 2021 21:19
Hi Waaren,
Yes it is but my latest post contain some other settings for /etc/init.d/domoticz.sh that will cause domoticz to log (much) more.
Posted: Friday 19 February 2021 22:25
by Bospieper
I see my mistake, will adjust it now.
Posted: Saturday 20 February 2021 10:33
by Bospieper
Hi Waaren, in a effort to start debugging with a clean logfile something went wrong. I could not empty the file in the linux enviroment (not enough knowledge) so I stopped the domoticz service and copied the logfile to my windows pc, emptied the file and try to transfer it back to domoticz.
I have now a 0 Kb logfile. After that I started the deamon and domoticz services and then tried sudo trial -f var/log/domoticz.log. I see the cursor hangs and when I check the status of the domoticz service it says "killed". So I restart the domoticz service and it is up and running but my logfile remains empty.
Is this something witch can be fixed? I feel really stupid right now because this frustrates the proces in hopefully retrieving the main problem.
Piet
Posted: Saturday 20 February 2021 17:52
by waaren
Bospieper wrote: Saturday 20 February 2021 10:33
Did you try below commands?
sudo rm /var/log/domoticz.log
Posted: Saturday 20 February 2021 18:56
by Bospieper
no I didn't and yes I did now with the results in the attachment. At first nothing happend after the stop, rm and start. The cursor stayed at the left corner for at least 5 minutes then I interrupted the process with CTRL+C. After that I restart domoticz and its now up and running.
Unfortunately there's no domoticz.log in the /var/log/
Piet
