Bigger colorpicker windows
Posted: Monday 15 February 2021 11:24
by chrispazz
Hello, is it possibile to have a bigger colorpicker window?
When I use it on IPAD (with colorpicker:2) the frame is too little and it cannot detect my touches correctly (changing colortemp also changes dimmer).
Re: Bigger colorpicker windows
Posted: Monday 28 November 2022 18:24
by whoami
Hi Lokonli, is this already possible?
I have the same problem now with my dashboard, my fingers are to big to choose the right color.
Posted: Monday 12 December 2022 8:04
by whoami
Can I resize this screen bij myself? Is that also in the je version?
Thanks.
Posted: Thursday 21 December 2023 20:53
by whoami
Is this already an option? The color picker is still very small.
Posted: Thursday 28 December 2023 19:31
by whoami
@lokonli, can you check if this is possible?
Or is there another solution?
Posted: Thursday 28 December 2023 22:56
by Lokonli
Yes, it's possible, I'll add this to the next beta.
Posted: Friday 29 December 2023 10:08
by Lokonli
whoami wrote: Thursday 28 December 2023 19:31
Can you try latest beta?
Add the following to CONFIG.js:
This will scale the type-2 colorpicker popup window to 150% of it's original size.
You can also set colorpickerscale as block parameter.
Posted: Friday 29 December 2023 22:24
by HansieNL
Added this option to the general settings screen. Available with latest beta.
Posted: Wednesday 03 January 2024 18:49
by whoami
Lokonli wrote: Friday 29 December 2023 10:08
Yes it worked perfectly! Thanks.
Is it also possible to show the colorpicker always and not only when you tick the small dropdown menu? But just when you touch the button it opens direct the colorpicker? Also I dont get a colorpicker with dials, see my other post.
Posted: Wednesday 03 January 2024 20:06
by Lokonli
For a dial you have to set the switchMode to 'color', like:
blocks['rgb dial'] = {
idx: 14,
type: 'dial',
switchMode: 'color',
Did you try this already?
This will also on a regular block (latest beta only)
Posted: Wednesday 03 January 2024 22:07
by whoami
Lokonli wrote: Wednesday 03 January 2024 20:06
idx: 14,
type: 'dial',
Yes installing latest beta made it work!
Is there also a time-out possible for the color picker? Now it doesn’t disappear automatically
Posted: Saturday 06 January 2024 21:06
by whoami
idx: 14,
type: 'dial',
The color picker stays in the screen even when dashticz is going back to screen 1 after the time out.
I have to click somewhere else on the screen to get the color picker away.
Can I set an autoclose timer on the color picker?
