Bigger colorpicker windows
Hello, is it possibile to have a bigger colorpicker window?
When I use it on IPAD (with colorpicker:2) the frame is too little and it cannot detect my touches correctly (changing colortemp also changes dimmer).
whoami
- Target OS: -
Re: Bigger colorpicker windows
Hi Lokonli, is this already possible?
I have the same problem now with my dashboard, my fingers are to big to choose the right color.
whoami
- Target OS: -
Can I resize this screen bij myself? Is that also in the je version?
Thanks.
Thanks.
whoami
- Target OS: -
Is this already an option? The color picker is still very small.
whoami
- Target OS: -
@lokonli, can you check if this is possible?
Or is there another solution?
Lokonli
Yes, it's possible, I'll add this to the next beta.
Lokonli
Can you try latest beta?whoami wrote: Thursday 28 December 2023 19:31 @lokonli, can you check if this is possible?
Add the following to CONFIG.js:
config.colorpickerscale = 1.5
You can also set colorpickerscale as block parameter.
- HansieNL
Added this option to the general settings screen. Available with latest beta.
Blah blah blah
whoami
- Target OS: -
Yes it worked perfectly! Thanks.Lokonli wrote: Friday 29 December 2023 10:08Can you try latest beta?whoami wrote: Thursday 28 December 2023 19:31 @lokonli, can you check if this is possible?
This will scale the type-2 colorpicker popup window to 150% of it's original size.Code: Select all
Is it also possible to show the colorpicker always and not only when you tick the small dropdown menu? But just when you touch the button it opens direct the colorpicker? Also I dont get a colorpicker with dials, see my other post.
Lokonli
For a dial you have to set the switchMode to 'color', like:
Did you try this already?
This will also on a regular block (latest beta only)
blocks['rgb dial'] = {
idx: 14,
type: 'dial',
switchMode: 'color',
whoami
- Target OS: -
Yes installing latest beta made it work!Lokonli wrote: Wednesday 03 January 2024 20:06 For a dial you have to set the switchMode to 'color', like:
Did you try this already?Code: Select all
blocks['rgb dial'] = { idx: 14, type: 'dial', switchMode: 'color', }
Is there also a time-out possible for the color picker? Now it doesn’t disappear automatically
whoami
- Target OS: -
The color picker stays in the screen even when dashticz is going back to screen 1 after the time out.Lokonli wrote: Wednesday 03 January 2024 20:06 For a dial you have to set the switchMode to 'color', like:
I have to click somewhere else on the screen to get the color picker away.
Can I set an autoclose timer on the color picker?
