Is it possible to determine the source of the update of a device's value?
i.e. in a script, activated upon a device update, can I determine whether the change was due to an INCOMING data update, as opposed to a change to the device from another script for example?
Determine if script trigger is node update vs other script update
- Domoticz version: 2021.1
- Domoticz version: 2024.7
Re: Determine if script trigger is node update vs other script update
For a switch you can check the device log.
For a sensor I think the easiest way is to check the domoticz log file.
- waaren
A similar question was answered herelastofthejediknights wrote: ↑Sunday 14 February 2021 21:46 Is it possible to determine the source of the update of a device's value?
