Getting started, basic setup not working
Posted: Saturday 13 February 2021 9:42
by johansson
I've installed the latest beta (V3.7.3) based on the great instructions, but am having a probably simple/stupid problem: if I add no blocks or columns at all, I get all Domoticz devices as expected. If I copy-paste the basic custom layout with some of my own devices idx's, I get a blank page.
This produces a complete list of all Domoticz devices:
var config = {}
config['language'] = 'en_US'; //or: en_US, de_DE, fr_FR, hu_HU, it_IT, pt_PT, sv_SV
config['domoticz_ip'] = 'http://***.***.***.***:***';
config['user_name'] = '****';
config['pass_word'] = '****';
Just the connection stuff in custom.js
no blocks.png (197.98 KiB) Viewed 465 times
But when adding example blocks & columns, just a blank screen is shown:
var config = {}
//config['use_favorites'] = 0; //Request all Domoticz Devices, not only favorites
//config['auto_positioning'] = 0; // Use 0 this if you have defined your own columns
//Definition of blocks
blocks = {}
blocks[3] = {
  width: 6
blocks[34] = {
  width: 6
//Definition of columns
columns = {}
columns[1] = {
  //In this example: No blocks are defined in this column
  //This column will be empty
  width: 4
columns[2] = {
  blocks : [3, 34],
  width: 8
//Definition of screens
screens = {}
screens[1] = {
  columns: [1, 2]
Blank screen with blocks in custom.js
With blocks.png (253.22 KiB) Viewed 465 times
Cannot figure out what's going on, probably too simple but I'm lost - any pointers?
Re: Getting started, basic setup not working
Posted: Saturday 13 February 2021 12:22
by Lokonli
I guess device 3 and 34 are not marked as favorite in Domoticz.
Remove the two slashes before the config parameter, like this:
Posted: Saturday 13 February 2021 13:17
by johansson
Thanks for the tip, but unfortunately no help - one of the other was marked as favorite, the other one not. Choosing two non-favorite ones and removing the slashes had no impact, neither did two favorites with or without the slashes. I'm sure the solution is obvious, but I'm just missing something.
Posted: Sunday 14 February 2021 20:57
by Lokonli
There is a bug in beta: Each column must have a parameter 'block'
The block array can be empty, like this:
columns[1] = {
   blocks: [],
   width: 4
but the blocks parameter must be present.
Posted: Monday 15 February 2021 7:40
by johansson
Indeed, that was it - great, thanks! Now at least (only) the test devices are seen in Dashticz.
