Daily backup to external hdd - Suggestion.
Duivleo
- Domoticz version: v4.10717
I am not quite sure where to direct this topic to; but most likely the moderator knows to whom to send this mail to.
I am using the Taskplanner of Synology DAS to make a daily back-up of the Domoticz.db to a different drive, as per Wiki "Daily backup to external hdd".
It works fine; except for the deleting of files older then x days.
The script in the wiki-article states something like:
## Delete files older then 7 days
/usr/bin/find /volume1/Back-ups/Domoticz-backup/ -name '*.db' -type f -mtime +7 -delete
The term "-mtime" should be replaced with "-atime", since -mtime refers to the date the file was last modified. The backups are normally not modified, but only made. By using -atime, the "made date" is used and the script works fine and files older then 7 days are deleted.
Hope this will help.
Regards,
Leo
Regards,
Leo
- erem
- Domoticz version: 2021.1
Re: Daily backup to external hdd - Suggestion.
i had something similar to
in my backup.
However, if your backup fails for 7 consecutive days you lose all backups if this statement runs.
i now use to retain the last x backups
just my $.02
/usr/bin/find /volume1/Back-ups/Domoticz-backup/ -name '*.db' -type f -mtime +7 -deleteHowever, if your backup fails for 7 consecutive days you lose all backups if this statement runs.
i now use
RETAIN=4
RET=$(($RETAIN-1))
echo "Successful backup, retaining last $RET backup files"
ls -t $DIR/*.gz | tail -n +$RETAIN | xargs -r rm
just my $.02
Regards,
Rob
Rob
- madpatrick
- Domoticz version: 2026.1
I'm using rsnapshot. https://rsnapshot.org/download.html
Not sure if this is working on your distro
- Domoticz version: 2026.3
Are you saying it did not work with -mtime? Because atime is the time last accessed. And the backups are also not accessed...Duivleo wrote: Friday 12 February 2021 11:48 The term "-mtime" should be replaced with "-atime", since -mtime refers to the date the file was last modified. The backups are normally not modified, but only made. By using -atime, the "made date" is used and the script works fine and files older then 7 days are deleted.
What does ls -l in the folder say? Because that is showing the mtime.
Duivleo
The script as detailed in the WIKI was officially for a Pi. I have adapted it to run on a Synology NAS which I use.
Here, the -mtime did not work, but no fault-messages appeared when using Putty (via the NAS). See also later.
That made me to Google a bit more.
I found this:
https://www.hostinger.com/tutorials/how ... -in-linux/
QUOTE:
Searching by Time
If you want to search for files based on when they were accessed and modification time footprints. Linux keeps track of the files using these three timestamps.
Access Time (-atime) – when the file was either read or written into.
Modification Time (-mtime) – when the file was modified.
Change Time (-ctime) – when the file’s meta-data was updated.
This option has to be used with a number that specifies how many days passed since the file was accessed, modified or changed.
UNQUOTE.
Accoording to me: -atime refers to time when EITHER the file was assesed OR when data was written into it.
For me "data was written into it" is at the very start, i.e. at creation of the file.
Changinging contained data for me qualifies as 'modification'.
As via Putty no error messages were received when using -mtime, it appeared to me that -mtime is a valid option to use
but that, in my case, no files satisfied that very criteria of being modified.
After I changed -mtime to -atime, the script worked perfectly well.
Please do not get me wrong: I am not critisizing the author of the wiki; I am merely trying to improve that what
gave me headaches since I could not pinpoint the reason of the script not working.
Hopefully others will benefit from this.
For further details I refer to:
https://www.synology-forum.nl/synology- ... icseen#new
(The -l option I did not not use; I am not so profound with Linux, sorry.)
Regards,
Leo
I found this:
QUOTE:
Searching by Time
UNQUOTE.
Regards,
Leo
No problem Leo, I just wanted to be sure before I change something on the wiki.
Thank you for the explanation! I will change the wiki later this day.
- waaren
I just tested this on my NAS (DSM 6.2) and the find command does work exactly the same as on my Raspberry (buster) and NUC (bullseye)waltervl wrote: Friday 12 February 2021 21:21Are you saying it did not work with -mtime? Because atime is the time last accessed. And the backups are also not accessed...Duivleo wrote: Friday 12 February 2021 11:48 The term "-mtime" should be replaced with "-atime", since -mtime refers to the date the file was last modified. The backups are normally not modified, but only made. By using -atime, the "made date" is used and the script works fine and files older then 7 days are deleted.
/usr/bin/find --version
find (GNU findutils) 4.4.2
Copyright (C) 2007 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Written by Eric B. Decker, James Youngman, and Kevin Dalley.
Built using GNU gnulib version e5573b1bad88bfabcda181b9e0125fb0c52b7d3b
Features enabled: D_TYPE O_NOFOLLOW(enabled) LEAF_OPTIMISATION FTS() CBO(level=0)Code: Select all
ls -l findTest/*
-rwxrwxrwx 1 waaren users 151 Oct 27 2016 findTest/AddTime.sh
-rwxrwxrwx 1 waaren users 1828 Jul 11 2017 findTest/appenddomoticzlog.sh
-rwxrwxrwx 1 waaren users 2562 May 8 2020 findTest/Backup.sh
-rwxr-xr-x 1 root root 3661 Sep 18 2019 findTest/CheckAndrewFilesBackup.sh
-rwxrwxrwx 1 waaren users 1459 Sep 25 2018 findTest/CheckDomoticzMemory.sh
-rwxrwxrwx 1 waaren users 1254 Feb 17 2017 findTest/CheckDomoticzPidfile.sh
-rwxrwxrwx 1 waaren users 2079 Oct 7 2017 findTest/CheckDot.sh
-rwxrwxrwx 1 waaren users 442 Oct 3 2017 findTest/CheckFirewall.sh
-rwxrwxrwx 1 waaren users 3034 May 24 2018 findTest/CheckMobiles.sh
-rwxrwxrwx 1 waaren users 557 Dec 5 2016 findTest/CheckMyIP.sh
-rwxrwxrwx 1 waaren users 1807 Oct 5 2018 findTest/CheckMySQL.sh
-rwxr-xr-x 1 root root 3230 Jan 7 2019 findTest/CheckNASBackupServer.sh
-rwxrwxrwx 1 waaren users 807 Apr 5 2017 findTest/CheckNASBackup.sh
-rwxrwxrwx 1 waaren users 806 Dec 7 2016 findTest/CheckNASConfigBackup.sh
-rwxrwxrwx 1 waaren users 3202 Dec 18 2018 findTest/CheckNASFilesBackup.sh
-rwxr-xr-x 1 root root 825 Oct 21 2018 findTest/CheckProcesses.sh
-rwxrwxrwx 1 waaren users 570 Oct 30 2016 findTest/Cleanup.sh
-rwxrwxrwx 1 waaren users 1256 Oct 18 2018 findTest/CreateDomoticzBinaryBackup.sh
-rwxrwxrwx 1 waaren users 2425 Feb 11 2017 findTest/CreateExcelInput.sh
-rwxrwxrwx 1 waaren users 793 Sep 9 2017 findTest/DomoticzLogCheck.sh
-rwxr-xr-x 1 root root 3626 Dec 8 2018 findTest/ff.sh
-rwxrwxrwx 1 waaren users 457 Dec 5 2016 findTest/GetDomoticzlog.sh
-rwxrwxrwx 1 waaren users 4304 Sep 5 2017 findTest/GetEvoTemp.sh
-rwxrwxrwx 1 waaren users 575 Jul 11 2017 findTest/GetMyIP.sh
-rwxrwxrwx 1 waaren users 890 Feb 26 2017 findTest/GetPlexHistory.sh
-rwxrwxrwx 1 waaren users 212 Oct 27 2016 findTest/GrepDomoticzLog.sh
-rwxrwxrwx 1 waaren users 2078 Sep 8 09:21 findTest/HouseKeeping.sh
-rwxrwxrwx 1 waaren users 3689 Apr 28 2020 findTest/Init.sh
-rwxr--r-x 1 root root 955 Jul 15 2019 findTest/iscsiAlive.sh
-rwxr-xr-x 1 waaren users 166 Oct 27 2016 findTest/LogScriptUsage.sh
-rwxrwxrwx 1 waaren users 544 Sep 9 2017 findTest/MonitReload.sh
-rwxrwxrwx 1 waaren users 850 Feb 10 2017 findTest/PreventConflict.sh
-rwxrwxrwx 1 waaren users 4749 Feb 23 2017 findTest/pushover.sh
-rwxrwxrwx 1 waaren users 1708 Dec 1 2017 findTest/ReadAfvalwijzer.sh
-rwxrwxrwx 1 waaren users 94 Oct 27 2016 findTest/ReadDomoticzLog.sh
-rwxrwxrwx 1 waaren users 1204 Feb 10 2017 findTest/ReadHomeWizard.sh
-rwxrwxrwx 1 waaren users 928 May 28 2017 findTest/ReadPublicHoliday.sh
-rwxrwxrwx 1 waaren users 2942 Oct 27 2016 findTest/ReadWriteEnvoy.sh
-rwxrwxrwx 1 waaren users 853 Apr 9 2017 findTest/ResetDomoticz.sh
-rwxrwxrwx 1 waaren users 2041 Apr 7 2020 findTest/RootfsMySQL.sh
-rwxr--r-x 1 waaren waaren 2162 Sep 18 2018 findTest/rsync.sh
-rwxrwxrwx 1 waaren users 415 Mar 8 2017 findTest/SafeDomoticzlogIfCrashed.sh
-rwxrwxrwx 1 waaren users 243 Dec 12 2016 findTest/setsleep.sh
-rwxr-xr-x 1 root root 931 Oct 7 2017 findTest/ShutdownPI.sh
-rwxrwxrwx 1 waaren users 294 Dec 4 2016 findTest/SonosBridge.sh
-rwxrwxrwx 1 waaren users 1134 Jan 20 2017 findTest/StartDomoticz.sh
-rwxrwxrwx 1 waaren users 1109 Feb 13 2017 findTest/start-stop-CheckDomoticzPidfile.sh
-rwxrwxrwx 1 waaren users 1902 Mar 28 2017 findTest/start-stop-Fail2ban.sh
-rwxrwxrwx 1 waaren users 2206 Jan 21 2018 findTest/start-stop-Habridge.sh
-rwxr-xr-x 1 root root 1944 Jan 21 2017 findTest/start-stop-Plex.sh
-rwxrwxrwx 1 waaren users 2437 Jun 15 2020 findTest/TempAndVolumeInfo2Domoticz.sh
-rwxr-xr-x 1 root root 4282 Apr 28 2020 findTest/TempAndVolumeInfo2PI-1_Domoticz.sh
-rw-r--r-- 1 root root 3479 Mar 23 2018 findTest/TempAndVolumeInfo2PI-3_Domoticz.sh
-rwxrwxrwx 1 waaren users 585 Dec 12 2016 findTest/turn_SonosRadio_on.sh
-rwxrwxrwx 1 waaren users 586 Dec 20 2016 findTest/turn_tv_off.sh
-rwxrwxrwx 1 waaren users 732 Feb 10 2017 findTest/Write2MySQL.sh
touch -m findTest/C*
ls -l findTest/C*
-rwxr-xr-x 1 root root 3661 Feb 14 18:11 findTest/CheckAndrewFilesBackup.sh
-rwxrwxrwx 1 waaren users 1459 Feb 14 18:11 findTest/CheckDomoticzMemory.sh
-rwxrwxrwx 1 waaren users 1254 Feb 14 18:11 findTest/CheckDomoticzPidfile.sh
-rwxrwxrwx 1 waaren users 2079 Feb 14 18:11 findTest/CheckDot.sh
-rwxrwxrwx 1 waaren users 442 Feb 14 18:11 findTest/CheckFirewall.sh
-rwxrwxrwx 1 waaren users 3034 Feb 14 18:11 findTest/CheckMobiles.sh
-rwxrwxrwx 1 waaren users 557 Feb 14 18:11 findTest/CheckMyIP.sh
-rwxrwxrwx 1 waaren users 1807 Feb 14 18:11 findTest/CheckMySQL.sh
-rwxr-xr-x 1 root root 3230 Feb 14 18:11 findTest/CheckNASBackupServer.sh
-rwxrwxrwx 1 waaren users 807 Feb 14 18:11 findTest/CheckNASBackup.sh
-rwxrwxrwx 1 waaren users 806 Feb 14 18:11 findTest/CheckNASConfigBackup.sh
-rwxrwxrwx 1 waaren users 3202 Feb 14 18:11 findTest/CheckNASFilesBackup.sh
-rwxr-xr-x 1 root root 825 Feb 14 18:11 findTest/CheckProcesses.sh
-rwxrwxrwx 1 waaren users 570 Feb 14 18:11 findTest/Cleanup.sh
-rwxrwxrwx 1 waaren users 1256 Feb 14 18:11 findTest/CreateDomoticzBinaryBackup.sh
-rwxrwxrwx 1 waaren users 2425 Feb 14 18:11 findTest/CreateExcelInput.sh
Number of files in findTest before find -delete
ls -l findTest/* | wc -l
56
find /volume1/Synology/Domotica/findTest -name "*" -mtime +5 -delete
16
Thank you for checking this out on the Synology. I deleted the warning again on the wiki.waaren wrote: Sunday 14 February 2021 18:22I just tested this on my NAS (DSM 6.2) and the find command does work exactly the same as on my Raspberry (buster) and NUC (bullseye)waltervl wrote: Friday 12 February 2021 21:21Are you saying it did not work with -mtime? Because atime is the time last accessed. And the backups are also not accessed...Duivleo wrote: Friday 12 February 2021 11:48 The term "-mtime" should be replaced with "-atime", since -mtime refers to the date the file was last modified. The backups are normally not modified, but only made. By using -atime, the "made date" is used and the script works fine and files older then 7 days are deleted.
JanJaap
- Domoticz version: Dev
Hey,
I've been trying this script to run on my RPi 3B but it drives me crazy. I tweaked it a bit to get some logging on command line:
and it results in the following logging:
it looks like there is some hidden character at the end of the timestamp creation that puts the pointer back to front , so the line
the file extension is printed in the front of the logline.
Anyone some ideas?
### END OF USER CONFIGURABLE PARAMETERS
TIMESTAMP=`/bin/date +%Y%m%d%H%M`
echo "timestamp is $TIMESTAMP"
BACKUPFILE="domoticz_$TIMESTAMP.db" # backups will be named "domoticz_YYYYMMDDHHMMSS.db.gz"
BACKUPFILEGZ="$BACKUPFILE\.gz"
echo "BACKUPFILE is $BACKUPFILE"
echo "BACKUPFILEGZ is $BACKUPFILEGZ"
### create backup, ZIP it and start Domoticz again
echo create backup, ZIP it and start Domoticz again
#/usr/bin/curl -s http://$DOMO_IP:$DOMO_PORT/backupdatabase.php > /tmp/$BACKUPFILE
gzip -9 /tmp/$BACKUPFILE
### Send to Network disk through FTP
echo Send to Network disk through FTP
curl -s --disable-epsv -v -T"/tmp/$BACKUPFILEGZ" -u"$USERNAME:$PASSWORD" "ftp://$SERVER/media/hdd/Domoticz_backup/"
### Remove temp backup file
/bin/rm /tmp/$BACKUPFILEGZ
### Done!
echo Done!
start
timestamp is 202311112125
.dbKUPFILE is domoticz_202311112125
.db\.gzILEGZ is domoticz_202311112125
: No such file or directory12125
'!b\.gzan't open '/tmp/domoticz_202311112125
curl: try 'curl --help' or 'curl --manual' for more information
/bin/rm: cannot remove '/tmp/domoticz_202311112125'$'\r''.db\.gz'$'\r\r': No such file or directory
Done!
echo "BACKUPFILE is $BACKUPFILE"Anyone some ideas?
