Write logging to file in Windows
Plantje
Post by Plantje »
I have found https://www.domoticz.com/wiki/Windows?f ... AO4I_MjTnY with some guidelines as to how to setup logging for Windows. I am running Domoticz as a service so, I added
-log "C:\Program Files\Domoticz\log"
to the "AppParameters" in the registry. I have opened regedit as administrator and rebooted my system afterwards.
Still "C:\Program Files\Domoticz\log" stays empty.
How can I have Domoticz write the information that I see in the "Log" tab under the settings to a file?
I am trouble shooting a freezing system and I am wondering if just before the freeze anything note worthy happens in Domoticz
plugge
Re: Write logging to file in Windows
Post by plugge »
Plantje wrote: Thursday 11 February 2021 13:20 I have found https://www.domoticz.com/wiki/Windows?f ... AO4I_MjTnY with some guidelines as to how to setup logging for Windows. I am running Domoticz as a service so, I added
I made the same mistake. You must include the filename in the path:
-log "C:\Program Files\Domoticz\log\domoticz.log"
(for example)
Plantje
Post by Plantje »
Thank you very much!
Domoticz version: 2025.1
I updated the wiki to prevent more mistakes ;-)
Also this should be fixed in 2020.2 beta 12927 and upwards
Plantje
Post by Plantje »
waltervl wrote: Thursday 11 February 2021 16:37 I updated the wiki to prevent more mistakes ;-)
And I am running beta 12901 :)
Is the logging cleaned up automatically every now and then? I noticed the file is already 3MB. I hope it will be pretty useful the next freeze, but still....
Aaaaand, I wasn't able to find how to disable writing the log to a file again. Of course it will be possible by editing the registry again, but should be possible in a different way as well, right?
You could try to update to a newer beta and you will find out. I am just the messenger....
The file will definitely not cleanup by itself. But I have no idea how it can be switched off easy. Perhaps by edit /update the install through control panel, programs?
plugge
Post by plugge »
Plantje wrote: Thursday 11 February 2021 17:26 Aaaaand, I wasn't able to find how to disable writing the log to a file again. Of course it will be possible by editing the registry again, but should be possible in a different way as well, right?
As far as I know you will have to edit the registry and restart the Domoticz service, to make it read the registry again.
To rename the log file, I stop the service, rename the log file and start the service again.
Cumbersome, I know. I would love to see another solution.
The fix in 2020.2 beta 12927 doesn't work on my machine, for some reason.
I get a "parameter error" for NSSM (non sucking service manager) that puts the domoticz service in a "paused" state, similar to the previous build.
Haven't found the cause yet.
erem
Domoticz version: 2021.1
Post by erem »
i do not run domoticz on windows, but from general knowledge:
to truncate the log you can write a short cmd script like this
sc stop <domoticz service name>
del C:\Program Files\Domoticz\log\domoticz.log.old
ren C:\Program Files\Domoticz\log\domoticz.log C:\Program Files\Domoticz\log\domoticz.log.old
sc start <domoticz service name>
and run that as administrator from task scheduler at regular intervals
Regards,
Rob
plugge
Post by plugge »
erem wrote: Friday 12 February 2021 11:10 to truncate the log you can write a short cmd script like this
Not quite. "SC" won't stop and wait for a batch file to finish.
"net stop" waits a decent amount of time.
To keep the log file I use the following batch file, for those interested.
(Insert the correct path to the log file.)
echo off
for /f "delims=" %%a in ('wmic OS Get localdatetime ^| find "."') do set DateTime=%%a
set Yr=%DateTime:~0,4%
set Mon=%DateTime:~4,2%
set Day=%DateTime:~6,2%
set Hr=%DateTime:~8,2%
set Min=%DateTime:~10,2%
set Sec=%DateTime:~12,2%
net stop domoticz
ren "<Path to your logfile>\log\domoticz.log" "domoticz %Yr%-%Mon%-%Day% (%Hr%-%Min%-%Sec%).log"
net start domoticz
EXIT /B %ERRORLEVEL%
And define a task as administrator in Task Scheduler
Plantje
Post by Plantje »
Thanks a lot!
Would have been easy if this were part of the core functionality, but we'll have to make do! :)
Littlefield428
Post by Littlefield428 »
type PowerShell in search area and click on "Windows PowerShell"
If you have a .bat (batch) file go to step 3 OR copy your commands to a file and save it with .bat extension (e.g. file.bat)
run the .bat file with following command. PS (location)> <path to bat file>/file.bat | Tee-Object -file log.txt.
expresshr
Last edited by Littlefield428 on Friday 26 March 2021 5:21, edited 1 time in total.
plugge wrote: Friday 12 February 2021 0:06
The issue on github is reopened for the windows logging.
Can you test if the installation creates or edits the Regkey entries for logging?
plugge
Post by plugge »
waltervl wrote: Thursday 11 March 2021 11:57 The issue on github is reopened for the windows logging.
Found the culprit: the file path is created in the registry, but without quotes.
So, if the Domoticz log is in a path name with spaces inside, like "Program Files (x86)" nssm.exe wil stumble over the path.
That is most likely the reason why some people (@waaren) experience no problem when installing. Their path doesn't contain spaces
Because of this, I asked @gizmocuz to add the quotes, but apparently the quotes are removed somewhere in the process of writing the registry.
EDIT:
The quotes are there, but InnoSetup seems to remove them. (I'm not familiar with InnoSetup).
EDIT2:
Change your log file to a another path that does not contain spaces, f.e. C:\Users\<user>\Domoticzlog\domoticz.log and everything works fine.
plugge
[Solved] Re: Write logging to file in Windows
Post by plugge »
Fixed in version 2020.2.13077
