Hi All
I'm using an X branded cheap camera from Aliexpress.
I've found the RSTP URL using ONVIF Device Manager. I can get a stream through VLC, but when I put the same URL into Domoticz I can't get a stream.
Not sure if I'm missing something as this is my first attempt at cameras.
Your thoughts would be most helpful.
Raspberry Pi 3 Model B Rev 1.2
About Domoticz
Version: 2020.2
Build Hash: b63341bc0
Compile Date: 2020-04-26 23:47:55
dzVents Version: 3.0.2
Python Version: 3.7.3 (default, Jul 25 2020, 13:03:44) [GCC 8.3.0]
Fred
No stream
peerkersezuuker
Re: No stream
As far is i know domoticz supports only mjpeg streams.
So unless the camera is capable of streaming mjpeg, you need to convert the stream.
I believe some people use motion eye for motion detection and then restream the stream.
I self use zoneminder for motion detection and restreaming.
regards
regards
