Pushover
Posted: Tuesday 30 September 2014 21:05
by tre4bax
Hi There,
Has anyone used Pushover? I set this all up but it asks for a username and the only one I have is an email address. When you try and put that in using Domoticz it changes the @ to %40 and thus it does not seem to function.
What username do I need and how do I get it entered?
Trevor
Re: Pushover
Posted: Tuesday 30 September 2014 21:58
by bizziebis
You have to login at the website pushover.com.
There you'll find your User Key ( User ID field in Domoticz).
You have to Register an Application on the pushover website. That will give you an API Token/Key (API Key field in Domoticz)
When you fill in both fields with the values you now have, you can start receiving notifications.
Re: Pushover
Posted: Tuesday 30 September 2014 22:17
by tre4bax
Ah, Many thanks. I get it now. Seems to be working okay. If I can just fix it up so that the new version Domoticz boots on start again all will be well
Problem with Pushover configuration
Posted: Sunday 20 December 2015 15:20
by NLRad
I'm having trouble with configuring Pushover with Domoticz on my Raspberry Pi2B. I registered Domoticz as an app, then I filled in my user key en API token on the settings page. But if I push the Test button, in a red box the following message is displayed: Problem sending notification, please check the api key!
Anyone any suggestion?
Pushing notification from my desktop to my Pushover android client works just fine.
Re: Pushover
Posted: Monday 21 December 2015 7:26
by jannl
May be you have a white space before or after the api key?
Re: Pushover
Posted: Monday 21 December 2015 19:40
by NLRad
@jannl: thanks for your suggestion, but no, no leading or trailing spaces (I doublechecked).
See attached screenshot of the Domoticz Pushover configuration errormessage.
Re: Pushover
Posted: Tuesday 22 December 2015 7:15
by jannl
Not sure if for testing 'actief' must be checked.
Re: Pushover
Posted: Tuesday 22 December 2015 13:21
by hjvingen
I got this message also at first setup.
After saving settings and go back to testing, it worked for me.
Re: Pushover
Posted: Wednesday 23 December 2015 15:16
by NLRad
@hjvingen: yep, that did it. Thnx!
Re: Pushover
Posted: Sunday 22 January 2017 22:21
by antares
Hello!
I got this working now as well, and wonder how I can now send a push notification from LUA. Is there a 'SEND PUSHOVER' command?
Re: Pushover
Posted: Sunday 22 January 2017 22:42
by G3rard
Check this post
http://www.domoticz.com/forum/viewtopic ... 31&t=14884.
It's going to be implemented by ultratoto14.
