Yesterday, i installed zigbee2mqtt plugin and use the CC2531 stick. New hardware is allowed.
Everything went fine, until I changed the friendly name of the maindevices in the frontend of Z2M. The created subdevices are not responding anymore. However, the plugin still updates it’s maindevices.
Even when I delete a maindevice or subdevice in the plugin or even in Z2M frontend or Yaml, the plugin correctly recreates the device and it’s subdevices but still no input on the subdevices.
Restarted al services but nothing. All services are on the same machine.
Before I add more devices, I like to know what’s causing this.
No error in the domoticz log
RPi 4b, Domoticz 2020.2 (build 12709), Python Version: 3.7.3.
Thx in advance !
ZIGBEE2MQTT, subdevices not updating after friendly name change in Z2M frontend.
James83
- z2m.png (151.56 KiB) Viewed 873 times
RPI4, Philips Hue, Tradfri, Sonoff, MQTT, Zigbee2Mqtt, RFXCom 433, Octoprint,...
jannl
- Domoticz version: 2025.5.x
Re: ZIGBEE2MQTT, subdevices not updating after friendly name change in Z2M frontend.
Same here, got a solution?
jannl
A reboot solved it, and afterwards waking up the devices.
