Notification via nextcloud
m147
Post by m147 »
Based on this topic viewtopic.php?f=31&t=35252 I have made simple script to use Nextcloud as notification server.
Thx again @waaren ;)
return
    on =
        customEvents = { "notification" },
    logging = {
        level = domoticz.LOG_DEBUG,
        marker = notification,
    execute = function(dz, item)
        local function notify()
            local ADMIN = "adminuser"
            local TOKEN = "secret-token"
            local USER = "targetuser"
            local MESSAGE = item.data
            dz.executeShellCommand(
                command = 'curl -H "OCS-APIREQUEST: true" -X POST   https://'..ADMIN..':'..TOKEN..'@redandblack.cz/ocs/v2.php/apps/admin_notifications/api/v1/notifications/'..USER..'   -d "shortMessage='..MESSAGE..'"' ,
                timeout = 300,
        if item.isTimer or item.isDevice or item.customEvent then
            notify()
            dz.log(item,dz.LOG_DEBUG)
You can activate notification for example by MQTT:
mosquitto_pub -h domoticz -t domoticz/in -m '{"command":"customevent", "event":"notification","data":"message"}'
Or another dzVents script where will be executed:
domoticz.emitEvent('notification','message"')
I believe there are many users who uses Domoticz and also Nextcloud, so there will be no need to use 3rd party notification services like Pushbullet for them, since you can install Nextcloud app on any device.
Re: Notification via nextcloud
m147 wrote: Friday 22 January 2021 14:16 I believe there are many users who uses Domoticz and also Nextcloud, so there will be no need to use 3rd party notification services like Pushbullet for them, since you can install Nextcloud app on any device.
I added some checks and log messages to get the result visible
scriptVar = 'nextcloudPost'
return
    on =
         customEvents =
            scriptVar,
        shellCommandResponses =
            scriptVar,
    logging = {
        marker = scriptVar,
            local MESSAGE = item.data or ''
                timeout = 300,
                callback = scriptVar,
        if item.isTimer or item.isDevice or item.isCustomEvent then
            notify()
        elseif item.statusCode ~= 0 then
            dz.log('Problem occurred with curl command. Message is ' .. item.errorText ..'. Returncode is ' .. item.statusCode, dz.LOG_ERROR)
        elseif item.isXML then
            dz.utils.dumpTable(item.xml)
