Sensor for luminous intensity (lux)
Posted: Tuesday 19 January 2021 16:31
by JanvdW
At this moment my Domoticz is switching lights on and off depending on sunset and sunrise, but of course the light is also dependent on the weather (if it's cloudy or sunny makes a big difference). That's why I prefer to switch the lights dependent on the luminous intensity (lux value). I know that previously there was a solution based on Weather Underground, but that's not available anymore. I use OpenWeatherMap, which doesn't have a sensor for luminous intensity. Does anyone has a good alternative solution to retrieve the lux value for a specific location?
Posted: Tuesday 19 January 2021 16:57
by Treve
I’m using (for years now) for that purpose a Fibaro pir with a build in Lux sensor. Because there is to much light in the summer I’m using a piece of copy/printing paper as a filter. In combination with a blockly you can achieve exactly what you want.
The pir is looking outside at the attic to the sun.
Re: Sensor for luminous intensity (lux)
Posted: Tuesday 19 January 2021 17:16
by erem
Posted: Tuesday 19 January 2021 20:57
by JanvdW
Yes, thanks. I understand that one can install a private sensor. I was wondering if there is a public sensor (like Weather Underground had before), based on location (latitude, longitude).
Posted: Wednesday 20 January 2021 7:19
by Treve
I changed from a nearby (<500m) weather station to ‘Fibaro lux’ because the different brightness conditions on a distance of 500 meters. It was not secure enough.
Posted: Wednesday 20 January 2021 10:21
by JanvdW
Ok, that makes sense; thanks for the update
