Sensor for luminous intensity (lux)
JanvdW
Post by JanvdW »
At this moment my Domoticz is switching lights on and off depending on sunset and sunrise, but of course the light is also dependent on the weather (if it's cloudy or sunny makes a big difference). That's why I prefer to switch the lights dependent on the luminous intensity (lux value). I know that previously there was a solution based on Weather Underground, but that's not available anymore. I use OpenWeatherMap, which doesn't have a sensor for luminous intensity. Does anyone has a good alternative solution to retrieve the lux value for a specific location?
Treve
Domoticz version: v4.11474
Post by Treve »
I’m using (for years now) for that purpose a Fibaro pir with a build in Lux sensor. Because there is to much light in the summer I’m using a piece of copy/printing paper as a filter. In combination with a blockly you can achieve exactly what you want.
The pir is looking outside at the attic to the sun.
- RFXtrx433E,
- AEON Labs ZW090 Z-Stick Gen5 EU
- Hue v2.1
- Raspberry Pi 3 Model B, Raspbian Stretch Full on USB-Stick.
- Domoticz 4.11474
Devices: KaKu, Z-Wave, Hue.
for testing:
Raspberry 4, 2GB, SSD
Domoticz 2022.1
Ikea Hub, Fyrtur curtain
erem
Domoticz version: 2021.1
Re: Sensor for luminous intensity (lux)
Post by erem »
I use a WeMos D1 mini with ESPEasy and a BH1750 sensor
total cost < 5 EURO
WeMos D1 mini pro 4M: https://www.aliexpress.com/item/32831353752.html
sensor BH1750: https://www.aliexpress.com/item/32765542002.html
ESPEasy: https://www.letscontrolit.com/wiki/index.php/ESPEasy
Regards,
Rob
JanvdW
Post by JanvdW »
Yes, thanks. I understand that one can install a private sensor. I was wondering if there is a public sensor (like Weather Underground had before), based on location (latitude, longitude).
Treve
Post by Treve »
I changed from a nearby (<500m) weather station to ‘Fibaro lux’ because the different brightness conditions on a distance of 500 meters. It was not secure enough.
- RFXtrx433E,
- Hue v2.1
- Domoticz 4.11474
for testing:
Domoticz 2022.1
JanvdW
Post by JanvdW »
Ok, that makes sense; thanks for the update
