I have a sonoff TH10 running tasmota
It measures temperature and humidity, and is set up to talk to my local MQTT broker
Domoticz automatically discovers it as a switch, but so far I have been unable to get the temperature and humidity values into the system....
Any ideas?
Temperature and humidty from a TH10
- Domoticz version: 2024.7
Re: Temperature and humidty from a TH10
What plugin are you using to autodiscover your sensor? Did you check the forum topics and the github issues?
Ah - that may be the issue:
Of the two MQTT plugins I found, one supports dimmers but not sensors, one supports sensors but not dimmers
I'll take another look tonight!
