utc to local time  [Solved]
hestia
Domoticz version: 2022.1
utc to local time
Post by hestia »
I don't understand how to use the DzVents methods: UTC, utcSystemTime, utcTime to convert an utc time like 202101132000 to the local time = 202101132100
Somebody could give me an example?
Re: utc to local time
hestia wrote: Wednesday 13 January 2021 21:29 Somebody could give me an example?
There is no ready made method to go from a formatted string representing UTC time to a local time formatted string in dzVents but below example will show you how it can be done.
-- requires dzVents >= 3.0.17 (domoticz 2020.2 build 12702)
return
    on =
       timer =
           'every minute',
    logging =
        level = domoticz.LOG_DEBUG,
        marker = 'UTC example'
    execute = function(dz)
        local UTCtime = '202101132000'
        -- calculate the delta between UTC and local time
        local function getTimezone()
            local now = os.time()
            return math.floor(os.difftime(now, os.time(os.date("!*t", now))))
        -- Convert the string to an epoch time stamp and add timezone delta in seconds
        local myLocalTimestamp = dz.time.dateToTimestamp(UTCtime,'(%d%d%d%d)(%d%d)(%d%d)(%d%d)(%d%d)' )  + getTimezone()
        -- Convert the caclulated timestamp to the required format
        local localTime = dz.time.timestampToDate(myLocalTimestamp,'yyyymmddhhMM')
        dz.log('UTC time ' .. UTCtime .. ' = ' .. localTime ..  ' local time', dz.LOG_DEBUG)
hestia
Re: utc to local time  [Solved]
Post by hestia »
waaren wrote: Wednesday 13 January 2021 23:08 below example will show you how it can be done
return
    on =
       timer =
           'every minute',
    logging =
        dz.log('UTC time ' .. UTCtime .. ' = ' .. localTime .. ' local time, dz.LOG_DEBUG)
Thanks a lot waaren. Again!
I think there is a typo... I've changed this line:
to
dz.log('UTC time ' .. UTCtime .. ' = local Time ' .. localTime, dz.LOG_DEBUG)
Amazing if you didn't even run it once!!!
hestia wrote: Thursday 14 January 2021 9:00 Amazing if you didn't even run it once!!!
:oops: You give me too much credit. :D I tested it but made a last minute change when I posted it here.
Note to my self: Don't do this ;)
