Hi there,
cause a raspberry block, I had to restart it.
After many device didn't communicate with the Zwave network, so i deleted these from the Hardware page and then I included another time these in domoticz.
Now I see these in control panel and after each restart i see these on hardware page.
I don't know how I can remove these definitely.
I attached my control panel.
Thank you.
Remove deleted device
jefft
- Domoticz version: 2023.1
Re: Remove deleted device
You need to persuade the controller that they've failed. In the control panel, select the node and then in the controller drop-down, try repeating the commands 'Has node failed' and 'Refresh node info' a few times. That should cause the controller to query the node, get no response and eventually mark it dead; then you can remove the failed node. If that doesn't work, the only tool I've found that is better at removing devices if your z-wave controller is Aeotec, is Aeotec's Zendesk software; for other controllers (UZB etc), there might be a similar utility from their manufacturer.
Domoticz, Z-Stick Gen.5, zzh Zigbee, rxftrx433XL on Ubuntu 22.04, HP 290 G1.
Node Red, MQTT, 80+ Z-wave, ESP8266 & Shelly, handful of Zigbee bulbs. EMS-ESP gateway for Bosch boiler. Controlicz, until it dies :-(
- madpatrick
- Domoticz version: 2025.2
You can checkout this thread :
viewtopic.php?t=17497
Using the Z-way controller works to remove dead devices.
It is a powerfull tool, so be carefull
