Dear team,
Currently I am running Domoticz on a Raspberry Pi 3 without any problems so far. Domoticz runs here for a 433Mhz network (KiKa switches).
Can I use the same Domiticz to manage together with the Zigbee plugin a bridge to IKEA Trådfri, hence the manageIKEA bulbs?
That should mean that I use Domoticz for both managing 433Hz devices and this Zigbee plugin (with dongle) to communcate with IKEA Trådfri gateway.
Or should I best use another RPi for that with Domoticz only dedicated to Zigbee network?
Using Domiticz to communicate with IKEA Trådfri
Docdigit
- Domoticz version: 2020.2
With both feet on the ground you can't make any step forward...
Thorgal789
- Target OS: -
Re: Using Domiticz to communicate with IKEA Trådfri
If your question is "Can I use a 433 Mhz gateway with a Zigbee gateway on the sameRaspberry" ? Yes.
Docdigit
that is great. Can you hint me to a how-to somewhere?
- Domoticz version: 2026.3
Look at the following zigbee page for all info on gateways (all without 433 support)
https://www.domoticz.com/wiki/Zigbee#Zi ... n_Domoticz
Thorgal789
- Target OS: -
Just plug the Zigbee gateway on an USB port and the 433 mhz gateway on the other.
Or I haven't understand what you are asking ?
Docdigit
Sorry I respond so late.
Thanks, yes you did understand it. Only just I saw on Youtube that you don't need a Zigbee gateway to communicate using Wifi6. Is that correct?
Then Domoticz would fit the job functioning as the hub?
See cross post: viewtopic.php?f=24&t=35720&p=270230#p270230
Don't mix up Zigbee and Z-Wave
