Please help an idiot  [Solved]
theolsen
Post by theolsen »
I have plagiarised some script from here to get my WAN IP address and write it to a dummy text sensor.
That part works perfectly of course.
What I am trying to do is if that IP address does not match the address that I am expecting then turn on a light as a way of warning me.
Code I have messed up is below.
Basically, the light never comes on.
Can anyone tell me where I am going wrong?
Thanks in advance.
local getIp    = 'https://api.ipify.org/?format=json'
		timer =         { 'every minute' },
		httpResponses = { 'wanIP' }
	logging = {
        level = domoticz.LOG_FORCE,
        marker = '[WAN IP]'
	execute = function(dz, devNil)
    local actIP = dz.devices('Wan IP').text
      if (devNil.isTimer)  then
            dz.log("Send WanIP request")
            dz.openURL({
                url = getIp,
                method = 'GET',
                callback = 'wanIP'
        elseif (devNil.isHTTPResponse) then
            dz.log("WanIP response")
            if (devNil.ok) then -- statusCode == 2xx
                newIP = devNil.json.ip
            if newIP ~= actIP then
                dz.devices('Wan IP').updateText(newIP)
                if newIP ~= '195.150.251.189' and newIP ~= 'nil' then
                     execute = function(domoticz, doit)
                local light = domoticz.devices('Hallway')
              light.switchOn()
Re: Please help an idiot  [Solved]
theolsen wrote: Thursday 07 January 2021 14:12 What I am trying to do is if that IP address does not match the address that I am expecting then turn on a light as a way of warning me.
Hard to tell without the log.
This should do it and if not please show the loglines
local scriptVar = 'wanIP'
return
    on =
        timer =
            'every minute',
        httpResponses =
            scriptVar,
    logging = {
        marker = '[WAN IP]',
    execute = function(dz, item)
        local hallWay = dz.devices('Hallway')
        local defaultIP = '195.150.251.189'
        if item.isTimer then
            dz.openURL(
                url = getIp,
                callback = scriptVar,
        elseif item.isHTTPResponse and item.json then
            local newIP = item.json.ip
            if newIP and newIP ~= actIP.text then
                actIP.updateText(newIP)
            if newIP and newIP ~= defaultIP then
                hallWay.switchOn()
            dz.log('Problem with HTTP response', dz.LOG_ERROR)
            dz.log(item, dz.LOG_DEBUG)
theolsen
Post by theolsen »
waaren, you are a god amongst men.
Worked perfectly. Thank you so much.
