openpopup - refused to connect.
Posted: Thursday 07 January 2021 13:44
by DeVille70
I have defined a block to openpopup with a url to a public wet site. The pop up window opens, but only show "refused to connect". This is indepedant from the url, I even tried the simple
https://www.vg.no/ but same output.
Anyone who can help?
Re: openpopup - refused to connect.
Posted: Thursday 07 January 2021 14:51
by DeVille70
Seems to a problem only with urls with https - as http works fine.
Posted: Friday 08 January 2021 14:02
by Lokonli
DeVille70 wrote: Thursday 07 January 2021 14:51
Some sites do not allow to present the content in a iframe, like vg.no
(by setting the X-Frame-Options http header)
By adding forcerefresh:2 as block parameter, the content is loaded via the Dashticz CORS proxy that strips out the X-frame-option as well, so you see some content, although most internal links and images will not be present.
There is no easy workaround as far as I know.
What I could is add the option to open the popup window in a separate window. Would that be useful?
Posted: Friday 08 January 2021 14:35
by DeVille70
Thanks.
forcerefresh:2 works as you said, but also has the limitations that you indicated, so it does not really do the trick.
A separate window would be fine. Grateful if you could give me a pointer on how to do that.
Alternatively, can the 'buttons' defintion be used in any useful way to overcome this?
Thanks again for your support.
Posted: Friday 08 January 2021 15:32
by Lokonli
For 'url' parameters the 'newwindow' parameter is used to determine whether the url will be opened in a new window. as a new tab or as an popup frame. The same mechanism could be used for openpopup(OnOff). Currently openpopupOnOff will always open a popup frame.
I want to keep 'autoclose' functionality. I'll do some tests.
Posted: Sunday 10 January 2021 19:59
by DeVille70
newwindow 0 or 1 works as intended, but both have undesired side effects that i had not considered. Since I use WallPanel for a clean interface, I have no button for back or any option to close current window.
Any ideas much appreciated.
Posted: Sunday 10 January 2021 20:37
by Lokonli
DeVille70 wrote: Sunday 10 January 2021 19:59
When it's not allowed to show the url in a frame, then the options are limited.
I can add autoclose support for new windows.
Posted: Sunday 10 January 2021 20:49
by Lokonli
And with Fully Kiosk you could add a 'back' button at the top, which will close the new window.
Posted: Monday 11 January 2021 21:46
by DeVille70
An option to autoclose new windows would be great, thanks.
