openpopup - refused to connect.
DeVille70
I have defined a block to openpopup with a url to a public wet site. The pop up window opens, but only show "refused to connect". This is indepedant from the url, I even tried the simple https://www.vg.no/ but same output.
Anyone who can help?
DeVille70
Re: openpopup - refused to connect.
Seems to a problem only with urls with https - as http works fine.
Lokonli
Some sites do not allow to present the content in a iframe, like vg.noDeVille70 wrote: Thursday 07 January 2021 14:51 Seems to a problem only with urls with https - as http works fine.
(by setting the X-Frame-Options http header)
By adding forcerefresh:2 as block parameter, the content is loaded via the Dashticz CORS proxy that strips out the X-frame-option as well, so you see some content, although most internal links and images will not be present.
There is no easy workaround as far as I know.
What I could is add the option to open the popup window in a separate window. Would that be useful?
DeVille70
Thanks.
forcerefresh:2 works as you said, but also has the limitations that you indicated, so it does not really do the trick.
A separate window would be fine. Grateful if you could give me a pointer on how to do that.
Alternatively, can the 'buttons' defintion be used in any useful way to overcome this?
Thanks again for your support.
Lokonli
For 'url' parameters the 'newwindow' parameter is used to determine whether the url will be opened in a new window. as a new tab or as an popup frame. The same mechanism could be used for openpopup(OnOff). Currently openpopupOnOff will always open a popup frame.
I want to keep 'autoclose' functionality. I'll do some tests.
DeVille70
newwindow 0 or 1 works as intended, but both have undesired side effects that i had not considered. Since I use WallPanel for a clean interface, I have no button for back or any option to close current window.
Any ideas much appreciated.
Lokonli
When it's not allowed to show the url in a frame, then the options are limited.DeVille70 wrote: Sunday 10 January 2021 19:59 newwindow 0 or 1 works as intended, but both have undesired side effects that i had not considered. Since I use WallPanel for a clean interface, I have no button for back or any option to close current window.
I can add autoclose support for new windows.
Lokonli
And with Fully Kiosk you could add a 'back' button at the top, which will close the new window.
DeVille70
An option to autoclose new windows would be great, thanks.
