I have a need to monitor three power consumption values within a single consumer unit.
I've used Owl devices in the past and my first thought was to use these but I don't have an RFXtrx433XL USB HA and they appear to be unavailable everywhere.
Ideally I'd like a solution that uses clamp sensors that split to allow them to attached without breaking the seals on anything.
My plan is to have a Pi running Domoticz located by or somewhere close to the consumer unit to act as a data source for my primary Domoticz server which is virtualised and has no physical ports.
I've spotted the pzem-004t option but this appears to be a closed ring and would need a PSU and enclosure, i.e. finishing off.
If people could let me know what they have used and if they think it's still available I'd be very grateful.
Kind regards
Charles
OWL and RFXtrx433XL USB HA alternative
Charles (pecccl)
Re: OWL and RFXtrx433XL USB HA alternative
A good solution, without a doubt, is to have an RFXtrx433E USB 433.92MHz Transceiver card, and use the EX equipment. OWL CM 180 with clamp sensors.
Works perfect! But I only have one clamp.
It may not be easy to arrange the equipment at the moment but,try to find the sale, in my opinion with clamp sensors, OWL was a good solution!
Agree but from the manufacturers website "RFXtrx433XL not available. Unknown if or when a new product becomes available."
I can't find any for sale anywhere so I've messages the manufacturer.
If anyone has alternate suggestions or for a replacement for the RFXtrx433XL I would be very grateful.
Charles (pecccl)
What about RFLINK?
I don't have any experience with it but OWL support is documented.
I am also looking at this right now and an alternative may be the Aeotec Smart Energy meter (Same principle - can connect up to 3 clamps) - I have just posted a question on whether anybody has experience with this.
I currently have an RFXCOM but it's apparent discontinuation is making me nervous - If mine files I will have around 100 devices which won't be able to communicate to Domoticz.
RFXCom, Somfy RTS, 433Mhz Lighting, Evohome, Smart watering via Netatmo, solenoid valves, soil humidity sensors, Airthings Radon via bluetooth, Marley heat recovery fresh air units, Blue Iris, Alexa via DA Bridge.
Its not a shop i have meet! But i think they have RFXcom sale.pecccl wrote: ↑Monday 04 January 2021 18:11 Agree but from the manufacturers website "RFXtrx433XL not available. Unknown if or when a new product becomes available."
https://www.hashop.nl/rfxcom-budget-sch ... AHb3P0Yaak
Thank you Nefsoliove, i've just tried to order one and they are orderable but have none in stock.
Charles (pecccl)
