Modify P1 meter script solved  [Solved]
erijk999
Post by erijk999 »
How can I merge high and low consumption in this script?
--[[ this dzVents script collects the Used Energy in kWh for this year, this month, this week and today
           History:
            20200114: first release on forum (thx to OedzesG for the idea )
            20200120: Some small output lay-out changes
            20200205: Fixed bugs in comparing JSON date to currentdate in month and day (thx to @Kranendijk for reporting and testing )
            20200205: Use native WP.counterToday
            20200414: Adapted for WP energy production
            20200416: Made scriptVar Unique, added logline and reverted wrong calculation of seconds per day
local scriptVar = 'Used Energy'
return
    on =
        timer =
            'every 1 minutes',
        httpResponses =
            scriptVar .. '*',
    logging =
        level = domoticz.LOG_DEBUG,
        marker = scriptVar,
    data =
        Delivered =
            initial = {},
    execute = function(dz, item)
        -- ***** Your settings below this line
        local Delivered = dz.devices(1) -- change to name of your WPMeter between quotes or id without quotes
        local DeliveredText = dz.devices(25) -- text device showing WP Consumption
        -- ***** No changes required below this line
         local function getGraphData(period, id)
            if period == nil then period = 'year' end
            if id == nil then id = Delivered.id end
            url = dz.settings['Domoticz url'] .. '/json.htm?type=graph&sensor=counter&range=' .. period .. '&idx=' .. id
            dz.openURL({ url = url, callback = scriptVar })
        local function updateTextSensor()
            local lastWeek = dz.time.week - 1
            if lastWeek == 0 then lastWeek = 52 end
            DeliveredText.updateText
            '' .. string.format("%6.1f", dz.data.Delivered.year ) .. ' kWh ín ' .. os.date("%Y ",os.time()) .. '\n' ..
            '' .. string.format("%6.1f", dz.data.Delivered.month ) .. ' kWh ín ' .. os.date("%B %Y ",os.time()) .. '\n' ..
            '' .. string.format("%6.1f", dz.data.Delivered.week ) .. ' kWh ín ' .. 'Week ' .. dz.time.week .. ' of ' .. dz.time.year .. '\n' ..
            '' .. string.format("%6.1f", dz.data.Delivered.week2 ) .. ' kWh ín ' .. 'Week ' .. lastWeek .. ' of ' .. dz.time.year .. '\n' ..
            '' .. string.format("%6.1f", dz.data.Delivered.day ) .. ' kWh on ' .. os.date("%A %d %B %Y",os.time())
        local function processJSON(t)
            local yearVolume, monthVolume, weekVolume, week2Volume = 0, 0, 0, 0
            local currentMonthIdentifier = dz.time.rawDate:sub(1,4) .. '%-' .. dz.time.rawDate:sub(6,7)
            local day = 86400 -- (24 * 60 * 60)
            local startofWeek = os.date("%Y-%m-%d",os.time()- ( dz.time.wday - 2 ) * day)
            local startofLastWeek = os.date("%Y-%m-%d",os.time()- ( dz.time.wday + 5 ) * day)
            dz.log('wday: '  .. dz.time.wday,dz.LOG_FORCE)
	    dz.log('startofLastWeek: '  .. startofLastWeek,dz.LOG_FORCE)
	    dz.log('startofWeek: '  .. startofWeek,dz.LOG_FORCE)
            for index, Delivered in ipairs(t) do
                if Delivered.d:match(dz.time.year) then
                    yearVolume = yearVolume + Delivered.v
                if Delivered.d:match(currentMonthIdentifier) then
                    monthVolume = monthVolume + Delivered.v
                if Delivered.d >= startofWeek then
                    weekVolume = weekVolume + Delivered.v
                if Delivered.d >= startofLastWeek and Delivered.d < startofWeek then
			dz.log(Delivered,dz.LOG_FORCE)
			week2Volume = week2Volume + Delivered.v
            -- getGraphData('day' )
            dz.data.Delivered.day = Delivered.counterToday
            dz.data.Delivered.month = monthVolume
            dz.data.Delivered.year = yearVolume + 20
            dz.data.Delivered.week = weekVolume
            dz.data.Delivered.week2 = week2Volume
            updateTextSensor()
        -- main
        if item.isHTTPResponse and item.isJSON then
            processJSON(item.json.result)
        elseif item.isTimer or item.isDevice then
            getGraphData()
            dz.log('Error while retrieving Delivered data. Result is ' .. item.statusText ..' ; Response is: ' .. item.data,LOG_ERROR)
Re: Modify P1 meter script
erijk999 wrote: Monday 04 January 2021 11:18 How can I merge high and low consumption in this script?
Can you please elaborate a bit on what you want.
What device (idx, name, type, subtype) shows the high and low consumption?
How should the result be presented?
Did you search the forum for scripts already doing this? Did you look at the report option in the log of your P1 device?
erijk999
Post by erijk999 »
what I only want is that high and low consumption are added together from the p1 meter (idx1)
erijk999
Re: Modify P1 meter script  [Solved]
Post by erijk999 »
Solved
ikkuh
Re: Modify P1 meter script solved
Post by ikkuh »
nou, de oplossing zou wel handig zijn voor anderen!
