FibaroLink and HC3
laco
Domoticz version: 2021.1
FibaroLink and HC3
Post by laco »
Hello.
I am using Domoticz on Synology server version: 2020.2 (build 12728)
I bought a Fibaro HC3 gateway to which I want to send data from domoticz.
I created a virtual device Idx: 871 in domoticz and I want to send the status to the fiber of the binary switch ID 184
I activated fibarolink with ip address name and password, but I get an error message.
I don't know if this fibarolink also works with HC3.
Log error description:
2021-01-02 19:08:18.316 FibaroLink: sending value Off to property Power switch of virtual device id 184
2021-01-02 19:08:18.314 Status: User: admin (IP: 192.168.1.131) initiated a switch command (871/TEST/Off)
2021-01-02 19:08:18.338 Error: Error sending data to Fibaro!
2021-01-02 19:08:20.878 (VIRTUAL) Light/Switch (TEST)
2021-01-02 19:08:20.879 FibaroLink: sending value On to property Power switch of virtual device id 184
2021-01-02 19:08:20.876 Status: User: admin (IP: 192.168.1.131) initiated a switch command (871/TEST/On)
2021-01-02 19:08:20.895 Error: Error sending data to Fibaro!
JeroenL
Domoticz version: 2023.2
Re: FibaroLink and HC3
Post by JeroenL »
Fibaro link does also work with HC3
See more here:
https://en.domoticz.cn/forum/viewtopic.php?t=35370
Regards jeroen
