Dear people, i am a newbee and im proud to got the instal on mij raspberri pi. (domnoticz works fine)
A have a mqtt stick, it works fine i think, i can ad and a see the zigbee sensor but than... Nothing, got a tip i should test if the server is running, It dit not, so thats the problem. I found in ssh the error, but i have no clou..
Hope you know what i could do..
Best regards
Karel
● mosquitto.service - Mosquitto MQTT v3.1/v3.1.1 Broker
Loaded: loaded (/lib/systemd/system/mosquitto.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2020-12-30 21:47:33 CET; 1min 15s ago
Docs: man:mosquitto.conf(5)
man:mosquitto(8)
Process: 504 ExecStart=/usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf (code=exited, status=1/FAILURE)
Main PID: 504 (code=exited, status=1/FAILURE)
dec 30 21:47:33 raspberrypi systemd[1]: mosquitto.service: Service RestartSec=100ms expired, scheduling restart.
dec 30 21:47:33 raspberrypi systemd[1]: mosquitto.service: Scheduled restart job, restart counter is at 5.
dec 30 21:47:33 raspberrypi systemd[1]: Stopped Mosquitto MQTT v3.1/v3.1.1 Broker.
dec 30 21:47:33 raspberrypi systemd[1]: mosquitto.service: Start request repeated too quickly.
dec 30 21:47:33 raspberrypi systemd[1]: mosquitto.service: Failed with result 'exit-code'.
dec 30 21:47:33 raspberrypi systemd[1]: Failed to start Mosquitto MQTT v3.1/v3.1.1 Broker.
Version: 2020.2
Build Hash: b63341bc0
Compile Date: 2020-04-26 13:47:55
dzVents Version: 3.0.2
Python Version: 3.7.3 (default, Jul 25 2020, 13:03:44) [GCC 8.3.0]
Mqtt mosquitto on Domoticz
karelhuis
- Domoticz version: 2025.2
Bbless the telephone.
Labi Siffre.
Labi Siffre.
roadsnail
- Domoticz version: 13314
Re: Mqtt mosquitto on Domoticz
I presume you are using zigbee2MQTT as you mention Zigbee sensor (mqtt stick?). Maybe a cc2531?
Anyhow...
The last time I saw that error, I had edited the zigbee2MQTT configuration file at
/opt/zigbee2mqtt/data/configuration.yaml
and made a typing error! Luckily it was an easy fix, as it worked before I made the change, so I knew that my change must have caused the problem.
I suggest you check carefully all of the options in the configuration.yaml against the docs https://www.zigbee2mqtt.io/information/ ... ation.html
Anyhow...
_______________________________________________________________________________________________
Pi4, Z-Wave: Danfoss TRVs, aeotec hem, d-link siren, heiman door contacts. Hive heating ctrl, esp8266 based sensors, zigbee2mqtt, Zigbee bulbs etc
