fail2ban/domoticz
miralant
fail2ban/domoticz
Post by miralant »
I use on PIs and servers fail2ban to prevent brut force attack on SSH port. I've try to setup a jail to secure domoticz accordind to this tutorial : https://www.domoticz.com/wiki/Setup_fail2ban
After restart, it works (after 3 mistakes to logion page, the IP is push to iptables) but after several hours, the jail looks not fired :(
If I try regex (fail2ban-regex /tmp/domoticz.txt /etc/fail2ban/filter.d/domoticz.conf), it works. If I look to Top fail2ban is currently running.
I've try to restart f2b with systemctl restart fail2ban but the issue still present. If I reboot the Pi, it restarts working correctly. Strange :'
Thanks for your help.
raspbian : 10 buster
domoticz : 2020.2
Mira
erem
Domoticz version: 2021.1
Re: fail2ban/domoticz
Post by erem »
what do you mean when you write
>>the jail looks not fired.
i have a hard time understanding your issue.
Regards,
Rob
miralant
Post by miralant »
Sorry, i'll try to be more clear. #poorenglish
In fact, the domoticz jail works but after several hours it stops working. The jail is not triggered.
I need to fully restart Pi to fix the issue. (Systemctl restart won't fix...)
Egregius
Domoticz version: v2024.7
Post by Egregius »
If it's truly the jail that stops, isn't this something to take up with fail2ban instead of domoticz then?
miralant
Post by miralant »
For sure :D That's fail2ban issue not domoticz.
jvdz
Domoticz version: 4.107
Post by jvdz »
..or it is an iptables issue as that is what is being used by fail2ban. Did you check the status of iptables?
Jos
miralant
Post by miralant »
Iptables is kernel function. How check if it runs ? (Currently nothing in top)
jvdz
Post by jvdz »
You can show the current active jails:
sudo iptables -L -n
Jos
miralant
Post by miralant »
Nothing on my jails...what should I have ?
root@raspberrypi:/home/ced# sudo iptables -L -n
Chain INPUT (policy ACCEPT)
target prot opt source destination
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
I have the same return on Ubuntu server and SFTP jaiks is triggered.
