I'm running Dashticz on a Samsung Tab 3 8.0.
When I use a 4.4.2 ROM, Dashticz has no problem to swipe between pages. However, I can't have the interface in full screen. Today I tried again and in Chrome the weather icons didn't want to download, in the standard browser there was a warning about an invalid certificate from openweather
On any ROM I have tried of Android 5 - 7, I am able to 'expand desktop' and run any chosen app full screen. When I open Dashticz, the swipe action is a little sluggish, but acceptable for an old tablet. Over the hours the weather icons, buiienradar become almost unresponsive and by the hour it takes more time for a swipe to either swipe at all or animate to the next page. It can take up to 10 seconds, if it want to slide to the next page at all. Killing the Chrome process and restarting Dashtics resets the process, but over time it becomes just as bad.
I've tried Fully Kiosk on most ROM's, but that runs very sluggish everywhere.
Any idea what is causing this? I don't know about the 4.4.2 (Slimkat) ROM, but the Anddroid 5 and higher versions are either based on Cyanogen Mod or Lineage OS.
Slow response Dashticz over time on Android 5 and higher
Jimster
- Domoticz version: 2020.2
Re: Slow response Dashticz over time on Android 5 and higher
Try adding the following to the CONFIG.js for OWM:
config['use_cors'] = 1;-
Lokonli
How many devices do you have?jake wrote: Tuesday 29 December 2020 19:43 I'm running Dashticz on a Samsung Tab 3 8.0.
What is your domoticz_refresh value?
Do you see a difference if you make domoticz_refresh 10 times bigger?
jake
Yes, this did the trick. Does enabling this option also have a downside? I use PHP locally to avoid a remote cors proxy serverJimster wrote: Tuesday 29 December 2020 19:54 Try adding the following to the CONFIG.js for OWM:Code: Select all
jake
Altogheter I have 126 devices in domoticz (from the devices tab: used)Lokonli wrote: Tuesday 29 December 2020 21:55 How many devices do you have?
My refresh time was on 5. I have put it on 10, but to no avail. I finally came across a 4.4.4 ROM for the Tab 3, called SPIRIT. This ROM also has the option to expand desktop. Together with the config parameter use_cors = 1 I will give it a try. Somehow the ROMS above Android 4 have something in common that has gone for the worse, but I don't know what. If this ROM is stable and Dashticz doesn't degrade over time, I am happy!
- Sjonnie2017
- Domoticz version: Latest ß
Perfect! This line of code worked to get my old Lenovo Yoga Tablet to show the animated weather icons.Jimster wrote: Tuesday 29 December 2020 19:54 Try adding the following to the CONFIG.js for OWM:Code: Select all
Kudos to you!
YouLess Energy meter
