Legend of a graph of a dial
roblom
Post by roblom »
I've created a custom dial which works fine. But when I click on the dial a graph opens so this also works fine. But how can I change the legend of this graph (it's now hu_198 and te_198).
The settings below doesn't work
blocks['Badkamer'] = {
	idx: 198,
	title: 'Badkamer',
	type: 'dial',
	setpoint: 20,
	min: 15,
	max: 25,
	shownumbers: true,
	showring: true,
	showunit: true,
	last_update: false,
	width: 3,
	values : [
			value: 'Temp',
			idx: 198,
			unit: '°C',
			legend: 'Temperatuur'
			value: 'Humidity',
			idx: 198,
			icon: 'fas fa-tint',
			unit: '%',
			legend: 'Vochtigheid',
			value:'Barometer',
			idx: 135,
			icon: 'fas fa-cloud',
			unit:' hPa',
And also adding the code below doesn't change anything.
	legend: {
		hu_198: 'Vochtigheid',
		te_198: 'Temperatuur'
Lokonli
Re: Legend of a graph of a dial
Post by Lokonli »
The dial and graph are independent of each other.
To be able to configure the graph of a dial you have to explicitly set the popup parameter on the dial block, like:
   popup: 'BadkamerGraph',
blocks['BadkamerGraph'] = {
   devices: [198],
   legend: {
roblom
Post by roblom »
Thank you, that did the trick.
