I'm constantly receiving this error:
2020-12-23 10:25:31.854 Error: Tado: Received token is zero length.
2020-12-23 10:26:02.471 Error: Tado: Received token is zero length.
2020-12-23 10:26:33.127 Error: Tado: Received token is zero length.
2020-12-23 10:27:03.800 Error: Tado: Received token is zero length.
The thermostats seems to be working correctly.
Who can help?
Api error Tado plugin
Re: Api error Tado plugin
After re-entering my Tado-login on in the hardwarescreen the errors are gone.
Now my log says every 4 minutes:
2020-12-28 13:05:17.290 Status: Tado: Received access token from API.
2020-12-28 13:05:17.291 Status: Tado: Received refresh token from API.
2020-12-28 13:05:17.310 Status: Tado: Received access token from API.
2020-12-28 13:05:17.310 Status: Tado: Received refresh token from API.
2020-12-28 13:09:27.458 Status: Tado: Received access token from API.
2020-12-28 13:09:27.458 Status: Tado: Received refresh token from API.
2020-12-28 13:09:27.528 Status: Tado: Received access token from API.
2020-12-28 13:09:27.528 Status: Tado: Received refresh token from API.
Is there a way to suppress this?
