Page 1 of 2
LUA scene string
Posted: Sunday 20 December 2020 13:10
by bofisko
Please can you someone help me with lua scene in fibaro HC2?
I have string = "cool=0/0/0/0/0/10/59/206/46/37/36/23"
I would like to take number between "/" and assigned it for a month of the year. ( there are 12 number whitch show value device for month of the year)
Which command, function I should use for it?
Re: LUA scene string
Posted: Sunday 20 December 2020 14:06
by waaren
bofisko wrote: Sunday 20 December 2020 13:10
local myString = "cool=0/0/0/0/0/10/59/206/46/37/36/23"
local myTable = {}
local myMonth = 12
for str in myString:gmatch("(%d+)" ) do
table.insert(myTable, str)
print('Month: ' .. myMonth ..' ==> device: '.. myTable[myMonth])
Posted: Sunday 20 December 2020 18:54
by bofisko
THANK YOU IT IS WORKING!!
I get my years consumption from my DAIKIN per mouth.
I write this lua. I know that i possible to write better but it is my first work.
If someone to want to simplify I would like for it.
local id = fibaro:getSelfId();
local ip = fibaro:get(id, "IPAddress");
local port = fibaro:get(id, "TCPPort");
local Daikin = Net.FHttp(ip, port)
local a = {}
local b = {}
r,s,e = Daikin:GET("/aircon/get_year_power_ex")
if e == 0 then
i = 0
for v in string.gmatch(r, '([^,]+)') do
i = i + 1
a[i] = v
local myString = a[4]
local myTable = {}
local myMonth = 1
fibaro:debug('Month: ' .. myMonth ..' ==> device: '.. myTable[myMonth])
fibaro:debug('Month: ' .. myMonth+1 ..' ==> device: '.. myTable[myMonth+1])
fibaro:debug('Month: ' .. myMonth+2 ..' ==> device: '.. myTable[myMonth+2])
fibaro:debug('Month: ' .. myMonth+3 ..' ==> device: '.. myTable[myMonth+3])
fibaro:debug('Month: ' .. myMonth+4 ..' ==> device: '.. myTable[myMonth+4])
fibaro:debug('Month: ' .. myMonth+5 ..' ==> device: '.. myTable[myMonth+5])
fibaro:debug('Month: ' .. myMonth+6 ..' ==> device: '.. myTable[myMonth+6])
fibaro:debug('Month: ' .. myMonth+7 ..' ==> device: '.. myTable[myMonth+7])
fibaro:debug('Month: ' .. myMonth+8 ..' ==> device: '.. myTable[myMonth+8])
fibaro:debug('Month: ' .. myMonth+9 ..' ==> device: '.. myTable[myMonth+9])
fibaro:debug('Month: ' .. myMonth+10 ..' ==> device: '.. myTable[myMonth+10])
fibaro:debug('Month: ' .. myMonth+11 ..' ==> device: '.. myTable[myMonth+11])
Posted: Sunday 20 December 2020 23:44
by waaren
bofisko wrote: Sunday 20 December 2020 18:54
You could try this
local a = {}
if e == 0 then
for v in r:gmatch('([^,]+)') do
table.insert(a, v)
local myTable = {}
for str in a[4]:gmatch("(%d+)" ) do
fibaro:debug('Month: ' .. #myTable ..' ==> device: '.. myTable[#myTable])
Posted: Monday 21 December 2020 10:51
by bofisko
Thank it is better and working.
Posted: Monday 21 December 2020 11:09
by bofisko
Thanks your script working perfect.
Can you help me for the last time?
after this script I would like take acurrent Month from the my system and debug power the current month.
and also I would like to calculated consumption for the whole year.
So I will be have total consumption and current month consumption
It poible lat time?
Posted: Monday 21 December 2020 11:23
by waaren
bofisko wrote: Monday 21 December 2020 11:09
It poible lat time?
Cannot answer this yet because I don't have enough information.
Please describe in detail
- is this a script within domoticz or on the os level?
- where you get the data?
- how is the data formatted?
- where does it need to go?
Posted: Monday 21 December 2020 12:27
by bofisko
I put your script which you send me and I very thanks for it. I would like to modificate. I wrote some on the end of your script but not working for actual Month. ( because I am stupid)
I want to take from your script created table, number of Month (#myTable) and compare from number of current Month from the system fibaro
( date = os.date("*t", os.time()) - fibaro date
thisMonth = date.month ) - fibaro actual number of Month
script:
local a = {}
if e == 0 then
table.insert(a, v)
local myTable = {}
fibaro:debug('Month: ' .. #myTable ..' - '.. myTable[#myTable])
date = os.date("*t", os.time()) -- date from fibaro
thisMonth = date.month -- month from fibaro --now 12
for myTable in str do
if #myTable == thisMonth then
I had wrote in my system this before putting yours upadate script and it was working but I know that is not very good:
jan = myTable[myMonth]
feb=myTable[myMonth+1]
mar=myTable[myMonth+2]
apr=myTable[myMonth+3]
maj=myTable[myMonth+4]
jun=myTable[myMonth+5]
jul=myTable[myMonth+6]
aug=myTable[myMonth+7]
sep=myTable[myMonth+8]
okt=myTable[myMonth+9]
nov=myTable[myMonth+10]
dec=myTable[myMonth+11]
YEAR = jan+feb+mar+apr+maj+jun+jul+aug+sep+okt+nov+dec
fibaro:debug(YEAR)
Posted: Monday 21 December 2020 13:16
by waaren
bofisko wrote: Monday 21 December 2020 12:27
I am not sure I completely understand what you want but can you try this and share the result?
function tprint (t, indent, done)
local done = done or {}
indent = indent or 0
for key, value in pairs (t) do
pre = (string.rep (" ", indent)) -- indent it
if type (value) == "table" and not done[value] then
done [value] = true
fibaro:debug(pre .. tostring (key) .. ":");
tprint (value, indent + 2, done)
elseif type(value) == 'function' and not done[value] then
fibaro:debug( pre .. (tostring (key) .. "()"))
pre = pre .. (tostring (key) .. ": ")
fibaro:debug(pre .. tostring(value))
if e == 0 then
local a = {}
local myTable = {}
table.insert(a, v)
local yearTotal = 0
yearTotal = yearTotal + tonumber(str)
thisMonth = math.floor(os.date('%m'))
fibaro:debug('Month: ' .. thisMonth ..' - '.. myTable[thisMonth])
fibaro:debug('YearTotal: ' .. yearTotal)
fibaro:debug('-- Now dumping table a')
tprint(a)
fibaro:debug('-- Now dumping table myTable')
tprint(myTable)
Posted: Monday 21 December 2020 14:01
by bofisko
THANKS IT IS SUPER!!!
Posted: Monday 21 December 2020 14:20
by bofisko
waaren wrote: Monday 21 December 2020 13:16
Ewerithing is was working but there was only one little little problem in line 21 fibaro:debug(pre .. tostring(value) . There missing at the end of the symbol )
Now it i working Thank you very much for help me.
Posted: Monday 21 December 2020 20:42
by bofisko
It working but now I found that the data from strings a[4] are just cool data. data from strings a[2] are for heat. It possible to cool+heat (a[4] and a[2] together?
Posted: Monday 21 December 2020 21:03
by waaren
bofisko wrote: Monday 21 December 2020 20:42
As asked before please share the output you see. That will make it easier to help.
Posted: Tuesday 22 December 2020 0:22
by bofisko
ok:
API my daikin:
http://192.168.1.180/aircon/get_year_power_ex
string from API DAIKIN: ( number are consumption by months this year, prev year)
ret=OK,curr_year_heat=0/0/0/0/0/0/0/1/1/0/0/0,prev_year_heat=0/29/31/35/30/12/0/0/0/0/0/0,curr_year_cool=0/0/0/0/0/0/61/164/46/37/36/25,prev_year_cool=0/0/0/0/0/91/33/70/34/5/0/0
You givi me your script and I put in virtual device. But it is only for curr_year_cool. I would like to have consumption by month cool+heat and total consumption in my fibaro. Picture virtual device and VD in attachment. flb is file from fibaro export.
done [value] = true
if e == 0 then
local a = {}
local myTable = {}
table.insert(a, v)
local yearTotal = 0
local i=1
text ="ui.Label"..(i)..".value"
fibaro:call(id, "setProperty", text, "".. myTable[#myTable]*0.1 .. " kWh")
i=i+1
fibaro:call(id, "setProperty", "ui.Label13.value",'' .. yearTotal*0.1 .. " kWh")
fibaro:call(id, "setProperty", "ui.Label14.value", "" .. myTable[thisMonth]*0.1 .. " kWh")
Posted: Tuesday 22 December 2020 1:13
by waaren
bofisko wrote: Tuesday 22 December 2020 0:22
ok:
This should get you going..
done [value] = true
if e == 0 then
local a = {}
local myTable = {}
table.insert(a, v)
local yearTotal = 0
local function sum(line)
local total = 0
local myTable = {}
for str in line:gmatch("(%d+)" ) do
total = total + tonumber(str)
return myTable, total
local myHeatingTable, heatingTotal = sum(a[2])
local myCoolingTable, coolingTotal = sum(a[4])
tprint(a)
fibaro:debug('-- Now dumping heating and cooling tables')
tprint(myHeatingTable)
tprint(myCoolingTable)
fibaro:debug('Month total : ' .. thisMonth ..' - '.. ( myHeatingTable[thisMonth] + myCoolingTable[thisMonth] ) )
fibaro:debug('Year total: ' .. ( heatingTotal + coolingTotal ) )
Posted: Tuesday 22 December 2020 1:22
by bofisko
You are quickly. I will try it and send you result. Now I am going sleep because her is 2 o'clock in the morning. Thanks
Posted: Tuesday 22 December 2020 1:31
by bofisko
Sorry. but I think you probably didn't understand me. I would need this
January = cool january ( first number in string curr_year_cool) + heat january( first number in string curr_year_heat) and put in value in fibaro
February = cool february ( first number in string curr_year_cool) + heat february ( first number in string curr_year_heat)
I need count 2 table together.
Thank or is there?
MP
Posted: Tuesday 22 December 2020 1:40
by waaren
bofisko wrote: Tuesday 22 December 2020 1:31
Thank or is there?
The totals are the sum of cooling and heating
Posted: Tuesday 22 December 2020 1:46
by bofisko
so How can I get sum january and putting to value1 ? and How can I get um february? and puting to value2 etc?
Please because i do not understanding.
Posted: Tuesday 22 December 2020 1:52
by bofisko
It is not working. I get tablecool and tableheat but no together table. For example August there is iny table heat 1 , in table coll 164. I need prin table together and I need August 1+164= 165. After that i need send 165 to "ui.label8.value" which representative august. Other september in heat is 1 , september in coll is 46 I need 1+46=47 and after send number 47 to "ui.label9.value" which representative august.
I need split myHeatingTable + myCoolingTable to one togethertable and after take from this togethertable send value of the month to value 1-12.
MP
How can I do it? I need this in want.jpg in attachment.
mp
thanks
