Send email notifications when someone ring at the door
Posted: Tuesday 01 December 2020 21:39
Hello Team,
I'm requesting your help regarding a Ziglint Doorbell which I used with a homemade Rflink.
Actually the doorbell is detected like a Mertik_GV60 device.
Email sending is allready configured and works well
Good news, I have a new line created under the logs when someone is pressing the button.
Can you help me to send an email notification when this event happen ?
Link to the used Doorbell: https://www.amazon.co.uk/ZIGLINT-Waterp ... B07JGNXGL6
Logs from domoticz:
Logs from domoticz:
2020-11-28 22:29:26.724 Sunrise: 07:19:00 SunSet: 15:58:00
2020-11-28 22:29:26.725 Day length: 08:39:00 Sun at south: 11:39:00
2020-11-28 22:29:26.725 Civil twilight start: 06:43:00 Civil twilight end: 16:34:00
2020-11-28 22:29:26.725 Nautical twilight start: 06:04:00 Nautical twilight end: 17:13:00
2020-11-28 22:29:26.725 Astronomical twilight start: 05:26:00 Astronomical twilight end: 17:51:00
2020-11-28 22:29:26.553 Status: Domoticz V2020.2 (c)2012-2020 GizMoCuz
2020-11-28 22:29:26.553 Status: Build Hash: b63341bc0, Date: 2020-04-26 12:47:55
2020-11-28 22:29:26.554 Status: Startup Path: /home/pi/domoticz/
2020-11-28 22:29:27.066 Active notification Subsystems: email (1/13)
2020-11-28 22:29:27.163 Starting shared server on: :::6144
2020-11-28 22:29:27.051 Status: PluginSystem: Started, Python version '3.6.8'.
2020-11-28 22:29:27.087 Status: WebServer(HTTP) started on address: :: with port 8080
2020-11-28 22:29:27.109 Status: WebServer(SSL) started on address: :: with port 443
2020-11-28 22:29:27.163 Status: TCPServer: shared server started...
2020-11-28 22:29:27.164 Status: RxQueue: queue worker started...
2020-11-28 22:29:29.166 Status: EventSystem: reset all events...
2020-11-28 22:29:29.167 Status: NotificationSystem: thread started...
2020-11-28 22:29:29.172 Status: EventSystem: reset all device statuses...
2020-11-28 22:29:29.245 Status: PluginSystem: Entering work loop.
2020-11-28 22:29:29.316 Status: Python EventSystem: Initalizing event module.
2020-11-28 22:29:29.317 Status: EventSystem: Started
2020-11-28 22:29:29.317 Status: EventSystem: Queue thread started...
2020-11-28 22:29:29.368 Status: RFLink: Using serial port: /dev/serial/by-id/usb-1a86_USB2.0-Serial-if00-port0
2020-11-28 22:29:30.293 Status: RFLink: Controller Initialized!...
2020-11-28 22:29:30.369 Status: RFLink Detected, Version: 1.1 Revision: 48 Build: 4
2020-11-29 00:00:00.723 Sunrise: 07:21:00 SunSet: 15:57:00
2020-11-29 00:00:00.723 Day length: 08:37:00 Sun at south: 11:39:00
2020-11-29 00:00:00.723 Civil twilight start: 06:45:00 Civil twilight end: 16:33:00
2020-11-29 00:00:00.723 Nautical twilight start: 06:05:00 Nautical twilight end: 17:13:00
2020-11-29 00:00:00.723 Astronomical twilight start: 05:27:00 Astronomical twilight end: 17:51:00
2020-11-29 00:00:00.724 Status: EventSystem: reset all events...
2020-11-29 11:09:43.149 Status: Incoming connection from: 192.168.1.111
2020-11-30 00:00:00.671 Sunrise: 07:22:00 SunSet: 15:57:00
2020-11-30 00:00:00.671 Day length: 08:35:00 Sun at south: 11:39:00
2020-11-30 00:00:00.671 Civil twilight start: 06:46:00 Civil twilight end: 16:33:00
2020-11-30 00:00:00.671 Nautical twilight start: 06:06:00 Nautical twilight end: 17:12:00
2020-11-30 00:00:00.671 Astronomical twilight start: 05:28:00 Astronomical twilight end: 17:50:00
2020-11-30 00:00:00.672 Status: EventSystem: reset all events...
2020-11-30 09:24:52.347 Status: Incoming connection from: 192.168.1.11
[b]2020-11-30 12:30:15.549 (RFLink433) Light/Switch (DoorBell)[/b]
2020-11-30 12:32:17.833 Status: Incoming connection from: 192.168.1.74
[b]2020-11-30 16:52:38.998 (RFLink433) Light/Switch (DoorBell)[/b]
2020-12-01 00:00:00.791 Sunrise: 07:23:00 SunSet: 15:56:00
2020-12-01 00:00:00.791 Day length: 08:33:00 Sun at south: 11:40:00
2020-12-01 00:00:00.791 Civil twilight start: 06:47:00 Civil twilight end: 16:32:00
2020-12-01 00:00:00.791 Nautical twilight start: 06:07:00 Nautical twilight end: 17:12:00
2020-12-01 00:00:00.791 Astronomical twilight start: 05:29:00 Astronomical twilight end: 17:50:00
2020-12-01 00:00:00.792 Status: EventSystem: reset all events...
2020-12-01 13:17:38.819 Status: Incoming connection from: 192.168.1.11
[b]2020-12-01 15:42:57.447 (RFLink433) Light/Switch (DoorBell)[/b]
2020-12-01 16:35:30.368 Status: Incoming connection from: 192.168.1.11
