Page 1 of 2
Grayed-out UI item in Utility Sensors
Posted: Tuesday 01 December 2020 18:57
by philchillbill
Just noticed something I've never seen before, a dark/grayish UI entry for one of my sensors:
Any idea what causes it?
Re: Grayed-out UI item in Utility Sensors
Posted: Tuesday 01 December 2020 20:56
by waaren
philchillbill wrote: Tuesday 01 December 2020 18:57
Is this on the default theme?
Posted: Tuesday 01 December 2020 23:27
by philchillbill
waaren wrote:philchillbill wrote: Tuesday 01 December 2020 18:57
Yes
Greyed out sensor
Posted: Wednesday 02 December 2020 17:50
by MikeyMan
Just noticed today; one of the sensors being greyed out:
- Naamloos3.png (32 KiB) Viewed 2818 times
It is working; didn't see it before. What could this be?
Br,
Michael
Posted: Tuesday 08 December 2020 13:29
by MikeyMan
Anyone got any clue what causes this?
Posted: Monday 21 December 2020 12:58
by JohnOosterlaken
I have the same "issue" also with the water meter.
Posted: Wednesday 23 December 2020 21:39
by JohnOosterlaken
if fixed it by recreating the item via the GUI and not using a url.
it seems that this way the hardware type is not unknown anymore.
Posted: Wednesday 23 December 2020 21:51
by MikeyMan
JohnOosterlaken wrote: Wednesday 23 December 2020 21:39
Doesnt that screw up the history?
Posted: Monday 25 January 2021 8:00
by free_nsc
Go into Hardware -> select relevant item and check off Enabled tick box ☑ then click update
Posted: Monday 25 January 2021 10:28
by MikeyMan
Its not under hadeware i'm afraid.
Posted: Monday 25 January 2021 10:50
by waaren
MikeyMan wrote: Monday 25 January 2021 10:28
In domoticz terms a device object is connected to a hardware object.
If the hardware object is disabled (look at the hardware tab of your GU) and the hardware is one of the Python plugins, the device object tiles connected to that hardware object are greyed out in the switches-, weather, utility or temperature tab.
Posted: Monday 25 January 2021 10:53
by MikeyMan
Hmm... Strange... I recall it's always been the same, just not greyed out:
- 2021-01-25 10_52_48-Window.png (68.24 KiB) Viewed 2688 times
I dont think i ever had any hardware attached... And it is working as it should...
Very weird...
Posted: Monday 25 January 2021 11:24
by waaren
MikeyMan wrote: Monday 25 January 2021 10:53
It should not be possible to create a device without a 'parent' hardware without entering it directly in the database using an external program.
Also: devices are removed from the system when the 'parent' hardware is deleted in domoticz.
I can only guess what's happened but assume that some time in the past the hardware that this device was connected to was removed with an external program or something else in the database happened causing the connection between your device and the 'parent' to got lost.
I don't see any direct issue for the state of the system other then the greyed out tile but to be sure I would reconnect it to one of your hardware objects.
To identify all devices without a 'parent' hardware and to show all hardware objects can you please do
dzDir=/home/pi/domoticz # change to your domoticz dir
sudo sqlite3 --header $dzDir/domoticz.db "SELECT Name, Id , HardwareID FROM DeviceStatus WHERE HardwareID NOT IN (SELECT ID FROM Hardware)"
sudo sqlite3 --header $dzDir/domoticz.db "SELECT Id, Enabled, Type, Name FROM Hardware"
Posted: Monday 25 January 2021 11:49
by MikeyMan
Followed this guide:
https://ehoco.nl/watermeter-uitlezen-in ... on-script/
Dont see any hardware created here if i'm correct. So maybe the guide is not good
Posted: Monday 25 January 2021 12:04
by waaren
The guide is not complete.
in the line
http: //192.168.2.152:8080/json.htm?type=createvirtualsensor&idx=29&sensorname=Water&sensortype=113 ,
29 is the hardware ID. You should change that number to the ID of one of your hardware objects and preferable your "Dummy (Does nothing, use for virtual switches)" hardware as it shown on the hardware tab.
Posted: Monday 25 January 2021 14:02
by MikeyMan
waaren wrote: Monday 25 January 2021 12:04
in the line
Can i run that now still? Or will that mess up the history?
Posted: Monday 25 January 2021 15:17
by waaren
MikeyMan wrote: Monday 25 January 2021 14:02
No don't do that. Can you execute the sqlite3 commands I posted earlier? With that information I can advise you how to solve it.
Posted: Monday 25 January 2021 15:20
by MikeyMan
waaren wrote: Monday 25 January 2021 15:17
Sure!
Name|ID|HardwareID
Water|43|29
pi@raspberrypi:~ $ sudo sqlite3 --header $dzDir/domoticz.db "SELECT Id, Enabled, Type, Name FROM Hardware"
ID|Enabled|Type|Name
1|1|67|Domoticz Internal
2|1|4|Slimme Meter
3|1|75|Evohome
5|1|64|Zonnepanelen
6|1|15|Somfy Alarm
9|1|78|Weer
10|1|15|Graaddagen
11|1|15|Tempsensoren
13|1|94|Shelly
14|1|15|Backup
19|1|21|Zwave
Posted: Monday 25 January 2021 15:31
by waaren
MikeyMan wrote: Monday 25 January 2021 15:20
Name|ID|HardwareID
Water|43|29
OK. You can do
sudo service domoticz stop
sudo cp $dzDir/domoticz.db domoticz.db_keep # just to be sure
sudo sqlite3 $dzDir/domoticz.db "UPDATE DeviceStatus SET HardwareID = 1 WHERE ID = 43"
sudo service domoticz start
Check if OK.
Posted: Monday 25 January 2021 15:35
by MikeyMan
That fixed it!
- 2021-01-25 15_35_01-Window.png (67.36 KiB) Viewed 2660 times
Is that a reserved hardware ID? The internal one?
