Gledopto LED strip showing as motion
Posted: Monday 30 November 2020 16:33
by sundodger
Hi all, I just received a Gledopto LED strip and mini controller, i can get it to show up in Domoticz but when first connected shows as a motion sensor.
I can change this to Dimmer but get no option for colour etc either way it does not respond as any type of switch.
I have tried deleting it and re pairing multiple times same result.
As you can see in the pic its name is amended with _motion at the end which in my head is what is causing the problem.
All advice appreciated.
Re: Gledopto LED strip showing as motion
Posted: Monday 30 November 2020 18:21
by sundodger
Slight update to this, Updated zigbee2mqtt and it now is reported correctly in the Domoticz log but does not show in Devices.
One step forward one step back.
Posted: Monday 30 November 2020 19:09
by sundodger
after much poking about it turns out that a bit of tweaking was required.
Added it by following this viewtopic.php?t=29652
