Gledopto LED strip showing as motion
sundodger
Post by sundodger »
Hi all, I just received a Gledopto LED strip and mini controller, i can get it to show up in Domoticz but when first connected shows as a motion sensor.
I can change this to Dimmer but get no option for colour etc either way it does not respond as any type of switch.
I have tried deleting it and re pairing multiple times same result.
As you can see in the pic its name is amended with _motion at the end which in my head is what is causing the problem.
All advice appreciated.
sundodger
Re: Gledopto LED strip showing as motion
Post by sundodger »
Slight update to this, Updated zigbee2mqtt and it now is reported correctly in the Domoticz log but does not show in Devices.
One step forward one step back.
sundodger
Post by sundodger »
after much poking about it turns out that a bit of tweaking was required.
Added it by following this viewtopic.php?t=29652
