I read this: https://www.domoticz.com/wiki/Native_se ... ts_Encrypt and thought, that would be nice.
then i started following the steps and it sais to do sudo ./letsencrypt-auto, which is actually still really at the beginning of the procedure.
it starts with a few apt-get things and then tries to do some virualenv which fails. it then stops really not having done anything usefull except add crap to the disk.
it tells me this:
Creating virtual environment...
usage: virtualenv [--version] [--with-traceback] [-v | -q] [--app-data APP_DATA] [--reset-app-data] [--upgrade-embed-wheels] [--discovery {builtin}] [-p py] [--creator {builtin,cpython2-posix}] [--seeder {app-data,pip}] [--no-seed]
[--activators comma_sep_list] [--clear] [--system-site-packages] [--symlinks | --copies] [--no-download | --download] [--extra-search-dir d [d ...]] [--pip version] [--setuptools version] [--wheel version] [--no-pip]
[--no-setuptools] [--no-wheel] [--no-periodic-update] [--symlink-app-data] [--prompt prompt] [-h]
dest
virtualenv: error: unrecognized arguments: --no-site-packages
File "<stdin>", line 27, in <module>
File "<stdin>", line 19, in create_venv
File "/usr/lib/python2.7/subprocess.py", line 190, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['virtualenv', '--no-site-packages', '--python', '/usr/bin/python2.7', '/opt/eff.org/certbot/venv']' returned non-zero exit status 2is there anything simple i can do to make this work? or should i give up on the idea. I have worked with zero-ssl before, but domoticz does something weird with the certfile by adding things together in a single file, which i haven't really understood well, and i don't have the 'chain' bit from zero-ssl, although i might figure that out. i just liked the idea of a fully automated soltuion with letsencrypt.because i'm laz... no i just have so many other things to do.
any pointers would be highly appreciated
Cheers
Willem
