Help sensor motion 10 mins ago  [Solved]
Hydci
Domoticz version: 4.10717
Post by Hydci »
I wrote this automation in Dzvent I would like a helping hand because I think I was wrong I would like the notification of my motion sensor to be sent only when the previous ON state was 10 mins ago
    on = { devices = { ["Capteur BAT"] = {'at 8:00-20:00'} }
       execute = function(domoticz, item )
        if item.state == "On" and domoticz.devices("Capteur BAT").lastUpdate.minutesAgo >10 then
            os.execute("curl -u XXXXX:XXXXX -s -o /dev/null 2>&1 'http://XXXXXX:7080/send.html?smsto=XXXXXXXXX&smsbody=Courier+dans+la+bo%C3%AEte+au+lettre&smstype=sms'")
Re: Help sensor motion 10 mins ago
Hydci wrote: Saturday 21 November 2020 8:58 I wrote this automation in Dzvent I would like a helping hand because I think I was wrong I would like the notification of my motion sensor to be sent only when the previous ON state was 10 mins ago.
I don't know about the curl but the rest of the script seem to be OK.
You could check the logic with
return
    on =
        devices =
            ["Capteur BAT"] = {'at 8:00-20:00'},
   logging =
        level = domoticz.LOG_DEBUG,
        marker = 'lastUpdate Capteur BAT',
    execute = function(dz, item )
        if item.state == "On" and item.lastUpdate.secondsAgo > 20 then
            dz.log(item.name .. '.lastUpdate.secondsAgo = ' .. item.lastUpdate.secondsAgo .. ' seconds (> 20)',dz.LOG_DEBUG)
        elseif item.state == "On"  then
            dz.log(item.name .. '.lastUpdate.secondsAgo = ' .. item.lastUpdate.secondsAgo .. ' seconds (=< 20)' ,dz.LOG_DEBUG)
            dz.log('State of ' .. item.name .. ' is ' .. item.state,dz.LOG_DEBUG)
Hydci
Post by Hydci »
Hello @waaren
I haven't seen your answer before thank you that helped me get it working however I got an error adding a second sensor syntax error I don't think I'm wrong though
     on =
        devices =
            ["Capteur BAT", "Capteur Porte" ] = {'at 8:00-20:00'},
Re: Help sensor motion 10 mins ago  [Solved]
Hydci wrote: Wednesday 25 November 2020 15:14 I haven't seen your answer before thank you that helped me get it working however I got an error adding a second sensor syntax error I don't think I'm wrong though
I would not go as far to say it's wrong. Let's agree it's almost right..
Please try with:
     on =
        devices =
            ["Capteur Porte" ] = {'at 8:00-20:00'},
Hydci
Post by Hydci »
Hello, I confirm the syntax and the correct thanks for the help my script and add-in solved thank you
