Help needed with script  [Solved]
Fredom
Domoticz version: 2025.1
Post by Fredom »
Dear forum members who can get this script working for me.
I have already tried everything but unfortunately I cannot find it.
Thanks for the help.
--(dzVentz)--
--Door open  and 'DS' is On then no telegram
--Door open  and 'DS' is Off then send telegram with name of the door
--DS is Dummy switch that is on when smartphone is at home
--WCD On if 'DS'is Off and door state is Alarm, and switch Off when door state is Normal
--Door is an Kerui D026
--Telegram is not activated yet
local devicesToCheck = {
	 ['name'] = 'Voordeur',
	 ['name'] = 'Garagedeur',
	 ['name'] = 'Schuifdeur',
	 ['name'] = 'test',
return
	active = true,
    on =
        devices =
            'Voordeur','Garagedeur','Schuifdeur','test'
        logging = {
        level = domoticz.LOG_DEBUG,
        marker = "deur"
	execute = function(domoticz)
		    --for i, deviceToCheck in pairs(devicesToCheck) do
			local name = deviceToCheck['name']
			local state = domoticz.devices(name).state
            local light = dz.devices('DS')
            local lamp = dz.devices('WCD')
            local door = 'Voordeur','Garagedeur','Schuifdeur','test'
    execute = function(dz, door)
			if state == 'Alarm' and light =='active' then
			dz.devices ('WCD').switch.Off()
            return
        elseif not light.active then
               dz.devices ('WCD').switchOn()
    		   domoticz.telegram('Device ' .. name .. ' staat open ', domoticz.PRIORITY_HIGH)
And this is the log file from domoticz
2020-11-15 13:25:20.544 Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: /home/pi/domoticz/dzVents/runtime/EventHelpers.lua:661: bad argument #1 to 'pairs' (table expected, got string)
2020-11-15 13:25:21.609 Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: /home/pi/domoticz/dzVents/runtime/EventHelpers.lua:661: bad argument #1 to 'pairs' (table expected, got string)
2020-11-15 13:25:22.566 Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: /home/pi/domoticz/dzVents/runtime/EventHelpers.lua:661: bad argument #1 to 'pairs' (table expected, got string)
2020-11-15 13:25:23.600 Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: /home/pi/domoticz/dzVents/runtime/EventHelpers.lua:661: bad argument #1 to 'pairs' (table expected, got string)
2020-11-15 13:25:24.579 Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: /home/pi/domoticz/dzVents/runtime/EventHelpers.lua:661: bad argument #1 to 'pairs' (table expected, got string)
2020-11-15 13:25:25.545 Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: /home/pi/domoticz/dzVents/runtime/EventHelpers.lua:661: bad argument #1 to 'pairs' (table expected, got string)
2020-11-15 13:25:26.546 Error: EventSystem: in /home/pi/domoticz/dzVents/runtime/dzVents.lua: /home/pi/domoticz/dzVents/runtime/EventHelpers.lua:661: bad argument #1 to 'pairs' (table expected, got string)
Yours sincerely,
Fred
Rasberry Pi 3B+ - Debian Trixie - Domoticz 2025.2
RFLink - RFXCom - Zigbee (CC2531)
P1 Smart Meter - KaKu
Re: Help needed with script
Fredom wrote: Sunday 15 November 2020 13:45 Dear forum members who can get this script working for me.
Your dzVents script does contain some syntax and logic errors.
I corrected some but not sure if I catched all. If it not working as expected then please try to add more log statements and start with smaller steps.
--(dzVentz)--
    'Voordeur',
    'Garagedeur',
    'Schuifdeur',
    'test',
return
    on =
        devices = devicesToCheck,
    logging =
        marker = "deur",
    execute = function(dz)
        local name, state
        for _, deviceToCheck in ipairs(devicesToCheck) do
            state = dz.devices(deviceToCheck).state
            dz.log('state of ' .. deviceToCheck .. ' is ' .. state , dz.LOG_DEBUG)
            if state == 'Alarm' and light.active then
                lamp.switchOff()
                return
               lamp.switchOn()
               dz.notify('Devices', 'Device ' .. deviceToCheck .. ' staat open ')
Fredom
Post by Fredom »
Hi Waaren the script works almost fine.
the WCD turns on nicely when the 'DS' is not at home, but stays on.
Is it possible to switch off this WCD with a timer and or when the 'DS' comes home.
So whichever comes first.
There are no errors now in the log file
I am already very happy with this (fast) result
Gr
Fred
Yours sincerely,
Fred
Fredom wrote: Sunday 15 November 2020 20:32 Is it possible to switch off this WCD with a timer and or when the 'DS' comes home.
It is not clear from your description what you mean with DS comes home.
Good that the script is now without errors in the log but it would also help if you would show the other messages in the log produced by this script.
It would help to understand what kind of devices are involved and what states the can have.
Fredom
Post by Fredom »
waaren wrote: Sunday 15 November 2020 22:17
Okay I don't know yet where to find the other log files.
Or that must be the log files of the switches.
But I'll explain.
The 'DS' is a virtual on / off switch, which switches on as soon as a telephone comes into the house (via a ping script).
The 'WCD' is an on / off switch to switch lights (or something else).
The 'WCD' should then turn off with a timer or when 'DS' comes on.
I hope this is not too much to ask.
For me this is all (still) too difficult but i try to learn it.
Thank you in advance for your commitment
Yours sincerely,
Fred
Fredom wrote: Sunday 15 November 2020 22:52 Okay I don't know yet where to find the other log files.
I do not refer to other log files. You should see the lines from the debug logging in the same log where you first saw the errors.
What about the state "Alarm" ? Which device can report that state ?
if I understand it correctly below script should do what you describe.
--(dzVents)--
    'Voordeur',
    'Garagedeur',
    'Schuifdeur',
    'test',
return
    on =
    logging =
        marker = "deur",
        local name, state
        local delay = 300 -- set to amount of seconds the light should stay on
        local atHome = dz.devices('DS').active
        local wcd = dz.devices('WCD')
        if atHome then
            wcd.switchOff().checkFirst() -- phone is atHome so we can switchOff the wcd if it's on.
            for _, doorName in ipairs(devicesToCheck) do
                local door = dz.devices(doorName)
                dz.log('state of ' .. door .. ' is ' .. door.state , dz.LOG_DEBUG)
                if door.active or door.state == 'Open' then -- a door is open
                    wcd.cancelQueuedCommands()
                    wcd.switchOn()
                    wcd.switchOff().afterSec(delay)
                    dz.log('wcd activated for ' .. delay .. ' seconds.' , dz.LOG_DEBUG)
                    dz.notify('Devices', 'Device ' .. door .. ' staat open ')
                    break -- no need to look at the other doors
Fredom
Post by Fredom »
Hi Waaren,
The door switch is in an Kerui D026 it has an Alarm, a Normal, and a tamper alert.
Nothing happens when I open a door.
Not when phone is at home.
Not when the phone is out of the house.
No message on the screen (previous script is) and the WCD does not turn on.
There are now also errrors.
Domoticz log file:
2020-11-16 11:11:08.031 Error: dzVents: Error: (3.0.2) deur: An error occurred when calling event handler Deur open dan melding
2020-11-16 11:11:08.032 Error: dzVents: Error: (3.0.2) deur: ...ipts/dzVents/generated_scripts/Deur open dan melding.lua:42: attempt to concatenate a table value (local 'door')
2020-11-16 11:11:27.506 Error: dzVents: Error: (3.0.2) deur: An error occurred when calling event handler Deur open dan melding
2020-11-16 11:11:27.506 Error: dzVents: Error: (3.0.2) deur: ...ipts/dzVents/generated_scripts/Deur open dan melding.lua:42: attempt to concatenate a table value (local 'door')
2020-11-16 11:11:38.528 Error: dzVents: Error: (3.0.2) deur: An error occurred when calling event handler Deur open dan melding
2020-11-16 11:11:38.528 Error: dzVents: Error: (3.0.2) deur: ...ipts/dzVents/generated_scripts/Deur open dan melding.lua:42: attempt to concatenate a table value (local 'door')
2020-11-16 11:11:55.461 Error: dzVents: Error: (3.0.2) deur: An error occurred when calling event handler Deur open dan melding
2020-11-16 11:11:55.461 Error: dzVents: Error: (3.0.2) deur: ...ipts/dzVents/generated_scripts/Deur open dan melding.lua:42: attempt to concatenate a table value (local 'door')
Domoticz status file:
2020-11-16 11:18:43.765 Status: dzVents: Info: Handling events for: "test", value: "Alarm"
2020-11-16 11:18:43.765 Status: dzVents: Info: deur: ------ Start internal script: Deur open dan melding: Device: "test (RFX)", Index: 223
2020-11-16 11:18:43.767 Status: dzVents: Debug: deur: Processing device-adapter for DS: Switch device adapter
2020-11-16 11:18:43.768 Status: dzVents: Debug: deur: Processing device-adapter for WCD: Switch device adapter
2020-11-16 11:18:43.771 Status: dzVents: Info: deur: ------ Finished Deur open dan melding
2020-11-16 11:18:46.058 Status: dzVents: Info: Handling events for: "test", value: "Normal"
2020-11-16 11:18:46.058 Status: dzVents: Info: deur: ------ Start internal script: Deur open dan melding: Device: "test (RFX)", Index: 223
2020-11-16 11:18:46.059 Status: dzVents: Debug: deur: Processing device-adapter for DS: Switch device adapter
2020-11-16 11:18:46.060 Status: dzVents: Debug: deur: Processing device-adapter for WCD: Switch device adapter
2020-11-16 11:18:46.062 Status: dzVents: Info: deur: ------ Finished Deur open dan melding
I hope this help you
Yours sincerely,
Fred
Can you try again after changing line 42 from
to
dz.log('state of ' .. doorName .. ' is ' .. door.state , dz.LOG_DEBUG)
Fredom
Post by Fredom »
Hi Waaren,
The lamp now turns on nicely when opening the door.
But works only on the timer and not when closing the door before the timer.
I also changed line 44 from 'Open' to 'Alarm'
Also no notification on my screen.
Door open is 'Alarm'
Door closed is 'Normal'
There are also errors
Domoticz log file:
2020-11-16 14:11:24.144 Error: dzVents: Error: (3.0.2) deur: An error occurred when calling event handler Deur open dan melding
2020-11-16 14:11:24.144 Error: dzVents: Error: (3.0.2) deur: ...ipts/dzVents/generated_scripts/Deur open dan melding.lua:49: attempt to concatenate a table value (local 'door')
2020-11-16 14:11:35.730 Error: dzVents: Error: (3.0.2) deur: An error occurred when calling event handler Deur open dan melding
2020-11-16 14:11:35.730 Error: dzVents: Error: (3.0.2) deur: ...ipts/dzVents/generated_scripts/Deur open dan melding.lua:49: attempt to concatenate a table value (local 'door')
2020-11-16 14:12:09.942 Status: dzVents: Info: Handling events for: "test", value: "Alarm"
2020-11-16 14:12:09.942 Status: dzVents: Info: deur: ------ Start internal script: Deur open dan melding: Device: "test (RFX)", Index: 223
2020-11-16 14:12:09.944 Status: dzVents: Debug: deur: Processing device-adapter for DS: Switch device adapter
2020-11-16 14:12:09.946 Status: dzVents: Debug: deur: Processing device-adapter for WCD: Switch device adapter
2020-11-16 14:12:09.946 Status: dzVents: Debug: deur: Constructed timed-command: Off
2020-11-16 14:12:09.947 Status: dzVents: Info: deur: ------ Finished Deur open dan melding
2020-11-16 14:12:20.763 Status: dzVents: Info: Handling events for: "test", value: "Normal"
2020-11-16 14:12:20.763 Status: dzVents: Info: deur: ------ Start internal script: Deur open dan melding: Device: "test (RFX)", Index: 223
2020-11-16 14:12:20.764 Status: dzVents: Debug: deur: Processing device-adapter for DS: Switch device adapter
2020-11-16 14:12:20.766 Status: dzVents: Debug: deur: Processing device-adapter for WCD: Switch device adapter
2020-11-16 14:12:20.766 Status: dzVents: Debug: deur: Constructed timed-command: Off
2020-11-16 14:12:20.766 Status: dzVents: Info: deur: ------ Finished Deur open dan melding
Yours sincerely,
Fred
Fredom wrote: Monday 16 November 2020 14:38 The lamp now turns on nicely when opening the door. But works only on the timer and not when closing the door before the timer.
I was not aware of this requirement.
The dz.notify does not send anything to the screen it sends something to all configured notification subsystems.
Can you try this one?
--(dzVents)--
    'Voordeur',
    'Garagedeur',
    'Schuifdeur',
    'test',
return
    on =
    logging =
        marker = "deur",
        local name, state
        local allDoorsClosed = true
        if atHome then
                if door.active or door.state == 'Open' or door.state == 'Alarm' -- a door is open
                    allDoorsClosed = false
                    wcd.switchOn()
                    dz.notify('Devices', 'Device ' .. doorName .. ' staat open ')
            if allDoorsClosed then
                wcd.switchOff().checkFirst() -- All doors are closed so we can switchOff the wcd when it is on
Fredom
Post by Fredom »
Hi Waaren,
There is now an error for line 47
Also errors in the log files
This morning there was an outage with this forum.
Now I can no longer respond to your message and I can no longer use the select code, which is no longer there.
I also no longer get notifications of new messages.
Have restarted everything a few times but nothing helps.
Therefor, I send it this way.
Status
2020-11-16 15:28:04.829 Status: EventSystem: reset all events...
2020-11-16 15:28:04.831 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Energie.lua
2020-11-16 15:28:04.832 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Battery level.lua
2020-11-16 15:28:04.832 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Screen Slaapkamer.lua
2020-11-16 15:28:04.832 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Voordeur open licht aan.lua
2020-11-16 15:28:04.832 Status: dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Screen logeerkamer.lua
Log
2020-11-16 15:27:57.615 ...ipts/dzVents/generated_scripts/Deur open dan melding.lua:47: 'then' expected near 'allDoorsClosed'
2020-11-16 15:27:58.605 Error: dzVents: Error: (3.0.2) error loading module 'Deur open dan melding' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/Deur open dan melding.lua':
2020-11-16 15:27:58.605 ...ipts/dzVents/generated_scripts/Deur open dan melding.lua:47: 'then' expected near 'allDoorsClosed'
2020-11-16 15:27:59.608 Error: dzVents: Error: (3.0.2) error loading module 'Deur open dan melding' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/Deur open dan melding.lua':
2020-11-16 15:27:59.608 ...ipts/dzVents/generated_scripts/Deur open dan melding.lua:47: 'then' expected near 'allDoorsClosed'
2020-11-16 15:28:00.501 Error: dzVents: Error: (3.0.2) error loading module 'Deur open dan melding' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/Deur open dan melding.lua':
2020-11-16 15:28:00.501 ...ipts/dzVents/generated_scripts/Deur open dan melding.lua:47: 'then' expected near 'allDoorsClosed'
Yours sincerely,
Fred
Fredom wrote: Monday 16 November 2020 15:47There is now an error for line 47
Seems Murphy is visiting the forum... ;-)
corrected the error and added a log statement
--(dzVents)--
    'Voordeur',
    'Garagedeur',
    'Schuifdeur',
    'test',
return
    on =
    logging =
        marker = 'deur',
        local name, state
        dz.log('state of WCD is ' .. wcd.state , dz.LOG_DEBUG)
        dz.log('state of DS is ' .. dz.devices('DS').state .. '; atHome is ' .. tostring(atHome), dz.LOG_DEBUG)
        if atHome then
                if door.active or door.state == 'Open' or door.state == 'Alarm' then -- a door is open
                    wcd.switchOn()
Fredom
Post by Fredom »
Hi Waaren,
There are no more errors now.
But the lamp doesn't turn off on closing the door.
Lamp turns off only on the timer.
All other functions in order
I don't like Murphy
Yours sincerely,
Fred
Fredom
Post by Fredom »
Hi Waaren,
This is the Status file:
2020-11-16 16:43:15.323 Status: dzVents: Info: Handling events for: "Voordeur", value: "Normal"
2020-11-16 16:43:15.323 Status: dzVents: Info: deur: ------ Start internal script: Deur open dan melding: Device: "Voordeur (RFX)", Index: 103
2020-11-16 16:43:15.325 Status: dzVents: Debug: deur: Processing device-adapter for DS: Switch device adapter
2020-11-16 16:43:15.326 Status: dzVents: Debug: deur: Processing device-adapter for WCD: Switch device adapter
2020-11-16 16:43:15.326 Status: dzVents: Debug: deur: state of WCD is On
2020-11-16 16:43:15.326 Status: dzVents: Debug: deur: state of DS is Off; atHome is false
2020-11-16 16:43:15.326 Status: dzVents: Debug: deur: state of Voordeur is Normal
2020-11-16 16:43:15.326 Status: dzVents: Debug: deur: Constructed timed-command: On
2020-11-16 16:43:15.326 Status: dzVents: Debug: deur: Constructed timed-command: Off
2020-11-16 16:43:15.326 Status: dzVents: Debug: deur: Constructed timed-command: Off AFTER 30 SECONDS
2020-11-16 16:43:15.326 Status: dzVents: Debug: deur: wcd activated for 30 seconds.
2020-11-16 16:43:15.326 Status: dzVents: Info: deur: ------ Finished Deur open dan melding
Yours sincerely,
Fred
Fredom
Post by Fredom »
Hi Waaren,
After more testing.
If the telephone comes in and then closes the door, the lamp will go out immediately.
Otherwise, the lamp will only go out via the timer
I hope this helps you
Yours sincerely,
Fred
Fredom wrote: Monday 16 November 2020 17:02If the telephone comes in and then closes the door, the lamp will go out immediately. Otherwise, the lamp will only go out via the timer
Seems like the 'normal' state is also interpreted as being active.
--(dzVents)--
    'Voordeur',
    'Garagedeur',
    'Schuifdeur',
    'test',
return
    on =
    logging =
        marker = 'deur',
        local name, state
        if atHome then
                dz.log('state of ' .. doorName .. ' is ' .. door.state .. ' (' .. ( ( door.active and 'active' ) or 'not active' ) .. ')', dz.LOG_DEBUG)
                if door.state == 'Open' or door.state == 'Alarm' then -- a door is open
                    wcd.switchOn()
Fredom
Post by Fredom »
Hi Waaren,
There are no more errors in the domoticz log file
The working is now
Phone off and door open then light on then door close light off (oke)
Phone off and door open then light on then light off on timer (oke)
Phone off and door open then light on then phone at home light off on timer (prefer light direct off)
Phone off and door open light on then phone at home and then door closed (befor timer) then light off (oke if the light goes off by phone)
Prefer if posible light goes always off by phone at home
Status
2020-11-16 20:05:03.784 Status: dzVents: Info: Handling events for: "test", value: "Normal"
2020-11-16 20:05:03.784 Status: dzVents: Info: deur: ------ Start internal script: Deur open melding: Device: "test (RFX)", Index: 223
2020-11-16 20:05:03.786 Status: dzVents: Debug: deur: Processing device-adapter for DS: Switch device adapter
2020-11-16 20:05:03.787 Status: dzVents: Debug: deur: Processing device-adapter for WCD: Switch device adapter
2020-11-16 20:05:03.787 Status: dzVents: Debug: deur: state of WCD is On
2020-11-16 20:05:03.787 Status: dzVents: Debug: deur: state of DS is On; atHome is true
2020-11-16 20:05:03.787 Status: dzVents: Debug: deur: Constructed timed-command: Off
2020-11-16 20:05:03.787 Status: dzVents: Info: deur: ------ Finished Deur open melding
Yours sincerely,
Fred
Fredom wrote: Monday 16 November 2020 21:03 Prefer if posible light goes always off by phone at home
To do this the virtual phone switch should also trigger the script. Below modified version will do that.
--(dzVents)--
local doors =
    'Voordeur',
    'Garagedeur',
    'Schuifdeur',
    'test',
local allDevices = doors -- copy the doors table to table allDevices
table.insert(allDevices, 'DS') -- this will add this deviceName to the table allDevices
return
    on =
        devices = allDevices,
    logging =
        marker = 'deur',
        local ds = dz.devices('DS')
        local atHome = ds.active
        if atHome then
            for _, doorName in ipairs(doors) do
                    wcd.switchOn()
                    dz.log('wcd activated for ' .. delay .. ' seconds because ' .. doorName .. ' is open.' , dz.LOG_DEBUG)
                    break -- no need to look at the other doors if one is open.
Fredom
Post by Fredom »
Hi Waaren,
Thank you so much for perfecting this script to work perfectly now.
I am very happy now.
I also learned something from this.
Fred
Yours sincerely,
Fred
Fredom
Post by Fredom »
waaren wrote: Monday 16 November 2020 21:45
Hello Waaren
The script works verry well.
The notifications always come when a door opens, even when the phone is at home.
Phone at home then no notification.
No errors in de logfile
The message text comes from the doorswitch (notifications) and not from the script.
The message text is not a problem, I get the message in telegram that (name of) the door is open.
Is it possible that the message only comes when the door is open and the phone is not at home?
This would be the cherry on the cake
--(dzVents)--
--Door open  and 'Thuis' is On then no telegram
--Door open  and 'Thuis' is Off then send telegram with name of the door and door is open
--Thuis is Dummy switch that is on when smartphone is at home
--WCD On if 'Thuis'is Off and door state is Alarm, and switch Off when door state is Normal
--Telegram is activated
local doors =
    'Voordeur',
    'Garagedeur',
    'Schuifdeur',
    'Testdeur',  --for testing
table.insert(allDevices, 'Thuis') -- this will add this deviceName to the table allDevices
return
    on =
    logging =
        marker = 'deur',
        local Thuis = dz.devices('Thuis') --atHome
        local wcd = dz.devices('WCD') --Light switch
        local atHome = Thuis.active
        dz.log('state of Thuis is ' .. dz.devices('Thuis').state .. '; atHome is ' .. tostring(atHome), dz.LOG_DEBUG)
        if atHome then
                    wcd.switchOn()
This is what I have tried but with the same result
                    --dz.notify('Devices', 'Device ' .. doorName .. ' staat open ')
                elseif door.state =='Alarm' and not Thuis.active then
And this is the Status file
2020-11-18 20:28:45.951 Status: Notification: Testdeur geopend
2020-11-18 20:28:46.099 Status: dzVents: Info: Handling events for: "Testdeur", value: "Alarm"
2020-11-18 20:28:46.099 Status: dzVents: Info: deur: ------ Start internal script: Deur open melding telegram: Device: "Testdeur (RFX)", Index: 223
2020-11-18 20:28:46.100 Status: dzVents: Debug: deur: Processing device-adapter for Thuis: Switch device adapter
2020-11-18 20:28:46.102 Status: dzVents: Debug: deur: Processing device-adapter for WCD: Switch device adapter
2020-11-18 20:28:46.102 Status: dzVents: Debug: deur: state of WCD is Off
2020-11-18 20:28:46.102 Status: dzVents: Debug: deur: state of Thuis is On; atHome is true
2020-11-18 20:28:46.102 Status: dzVents: Debug: deur: Constructed timed-command: Off
2020-11-18 20:28:46.102 Status: dzVents: Info: deur: ------ Finished Deur open melding telegram
2020-11-18 20:28:55.392 Status: dzVents: Info: Handling events for: "Testdeur", value: "Normal"
2020-11-18 20:28:55.392 Status: dzVents: Info: deur: ------ Start internal script: Deur open melding telegram: Device: "Testdeur (RFX)", Index: 223
2020-11-18 20:28:55.395 Status: dzVents: Debug: deur: Processing device-adapter for Thuis: Switch device adapter
2020-11-18 20:28:55.397 Status: dzVents: Debug: deur: Processing device-adapter for WCD: Switch device adapter
2020-11-18 20:28:55.397 Status: dzVents: Debug: deur: state of WCD is Off
2020-11-18 20:28:55.397 Status: dzVents: Debug: deur: state of Thuis is On; atHome is true
2020-11-18 20:28:55.397 Status: dzVents: Debug: deur: Constructed timed-command: Off
2020-11-18 20:28:55.398 Status: dzVents: Info: deur: ------ Finished Deur open melding telegram
Hope you wil help me one more time
Fred
Yours sincerely,
Fred
