Option to change logging frequency of temperature devices
foxite
Post by foxite »
I built a system which publishes the temperature of a pump to MQTT every minute. Domoticz lets me see the current and historical temperature.
The only downside to this setup is that the graph is updated every 5 minutes, while the source updates every minute. I wasn't able to find a way to change the logging frequency of this graph. Assuming there is no way to do it, I'd like to propose this feature.
Re: Option to change logging frequency of temperature devices
foxite wrote: Saturday 14 November 2020 20:57 I built a system which publishes the temperature of a pump to MQTT every minute. Domoticz lets me see the current and historical temperature.
You can use the push functionality to influxDB if the 5 minute interval does not suite your needs. The required code modifications and the performance and database size implications of changing the 5 minutes interval for sensors would be quite significant and therefore not likely to be implemented.
EddyG
Post by EddyG »
Subscribe to domoticz/out and process in node-red the data every minute.
