Delayed switching  [Solved]
wahrens
Delayed switching
Post by wahrens »
I'm looking for a solution of the following idea:
Actually i'm using a door switch to shut my heating if the door is open and the outside temperatur is less than 15° C.
		devices = {
			'Tuer Wohnzimmer',
			'Zigbee Terrassentuer'
	    local WZHeat = domoticz.devices('WZ Heat')
	    local WZThermostat = domoticz.devices('WZ Thermostat');
	    local OAT = domoticz.devices('THB Darksky');
 	    if OAT.temperature < 15 then
    		if device.state == 'Open' then
                domoticz.log(device.name .." is now Open; setting Mode to Off")
                WZThermostat.updateMode('Off')
                -- WZHeat.updateSetPoint(16)
            elseif device.state == 'Closed' then
                domoticz.log(device.name .." is now Closed; setting Mode to Heat " )
                WZThermostat.updateMode('Heat')
This works fine, but i now look for a solution to only shut the heating if the door is not closed within 30 seconds or is open more than 30 seconds which is the same, but i dont know how to fix the timing problem.
Thanks for any idea
Matthiasfr
Re: Delayed switching
Post by Matthiasfr »
In Lua you can request current time. As soon as the door opens you can store this time. Maybe you can use a while loop that constantly checks current time. As soon as 30s are passend, you want to go out of the loop and re evaluate if the door is still open.
wahrens wrote: Monday 09 November 2020 11:49 i now look for a solution to only shut the heating if the door is not closed within 30 seconds or is open more than 30 seconds which is the same, but i dont know how to fix the timing problem.
Can you try with below script?
local scriptVar = 'delayedMode'
return
    on =
        devices =
            'Tuer Wohnzimmer',
            'Zigbee Terrassentuer',
        customEvents =
            scriptVar,
    logging =
        level = domoticz.LOG_DEBUG, -- set to domoticz.LOG_ERROR when all OK
        marker = scriptVar,
    execute = function(dz, item)
        local WZHeat = dz.devices('WZ Heat')
        local WZThermostat = dz.devices('WZ Thermostat')
        local OAT = dz.devices('THB Darksky')
        local wohnZimmerTuer = dz.devices('Tuer Wohnzimmer')
        local terrassenTuer = dz.devices('Zigbee Terrassentuer')
        local delay = 30
        local doorOpen = wohnZimmerTuer.state == 'Open' or terrassenTuer.state == 'Open'
            if item.isDevice then
                if not(doorOpen) then
                    dz.log('All doors closed; setting Mode to Heat', dz.LOG_DEBUG )
                    dz.log('At least one door is open. I will check again in ' .. delay .. ' seconds', dz.LOG_DEBUG)
                    dz.emitEvent(scriptVar).afterSec(delay)
            elseif doorOpen then
                dz.log('At least one door is still open; setting Mode to Off')
                dz.log('No action needed. (Door closed during delay)', dz.LOG_DEBUG )
            dz.log('No action needed. (temperature > 15)', dz.LOG_DEBUG )
Matthiasfr
Off course. You can simply use the delay functionality. :|
Matthiasfr wrote: Monday 09 November 2020 12:05 In Lua you can request current time. As soon as the door opens you can store this time. Maybe you can use a while loop that constantly checks current time. As soon as 30s are passend, you want to go out of the loop and re evaluate if the door is still open.
Please don't do this. It will block the domoticz eventSystem (classic Lua, dzVents and Blockly scripts) for the duration of the loop.
wahrens
Re: Delayed switching  [Solved]
Post by wahrens »
Thanks Waaren and Matthias !
Waarens script ist working fine.
Where can i find any documentation about: dz.emitEvent
wahrens wrote: Monday 09 November 2020 12:43 Where can i find any documentation about: dz.emitEvent
This wiki page seems to be a good start..
