Time widget
Dutchsea
Domoticz version: v2023.2
Time widget
Post by Dutchsea »
Is there a widget for setting a (alarm) time similar to the setpoint widget?
Thanks.
Raspberry PI 3B on USB drive, Debian version: 12 (bookworm), Domoticz 2024.7
Aeon Z-Wave G5 stick, RFXCOM, Sonof Zigbee 3.0 Dongle plus E, Nefit Easy, Fritzbox, Buienradar, Sonos
Re: Time widget
Dutchsea wrote: Saturday 31 October 2020 14:21 Hi,
Thanks.
No. You can simulate one with a selector switch
Dutchsea
Re: Time widget
Post by Dutchsea »
Right!
But there is probably there no possbility to have 2 selector buttons on the switch?
So I can make a 0 to 24h hour selector list and a 00 to 59 minute selector list?
Else i can only specify a limited number of "alarm times" in order not to make the list manageble.
Or is there a some other smarter way to similate a time with the selector switch?
Re: Time widget
Dutchsea wrote: Saturday 31 October 2020 20:23 Or is there a some other smarter way to similate a time with the selector switch?
You could try below script to set an Alarm time in a selector type switch
            dzvents script to use a selector type switch to set and display the set time
            selector levels must be set and named to:
            0    Off
            10   + 4 hours
            20   + 1 hour
            30   + 10 minutes
            40   + 1 minute
            50   - 4 hours
            60   - 1 hour
            70   - 10 minutes
            90   Alarm off
            100  Choose
            Off level must be set to "hided and for lay-out purposes best to set Selector Style to "select Menu"
            The name of the selector switch should initially be set to:     Alarm set for 08:00
return
    on =
        devices =
             689,  -- id of your selector type switch with initial name "Alarm set for 08:00" The name will change to include the time set
    logging =
        level = domoticz.LOG_DEBUG, -- set to domotiocz.LOG_ERROR when all OK
        marker =  ' set alarmTime' ,
    data =
        alarmTime =
            initial = 480,
    execute = function(dz, item)
        if item.levelName == 'Alarm off'  then
            item.rename('Alarm off')
            item.switchSelector('Choose').afterSec(1) -- force display of new name
            return
        if item.levelName ~='Choose'  then
            local sign = 1
            local multiplier = 60
            -- minutes to hh:mm
            local function timeFmt(min)
                hours = string.format("%02.f", math.floor(min/60) )
                minutes = string.format("%02.f", min - ( hours * 60 ) )
                return hours .. ':'  .. minutes
            local setTimeMinutes
            if item.name:match("%d+") == nil then
                setTimeMinutes = dz.data.alarmTime
                --get the time set in minutes
                setTimeMinutes = tonumber(item.name:match("%d+")) * 60 + tonumber(item.name:match(":(%d+)"))
            -- Plus or minus
            if item.levelName:find('-') then
                sign = -1
            -- Hours, minutes or 10 minutes
            if item.levelName:find('4') then
                multiplier = 240
            elseif item.levelName:find('10') then
                multiplier = 10
            elseif item.levelName:find('minute') then
                multiplier = 1
            -- new minutes
            local newTimeMinutes = ( setTimeMinutes + ( multiplier * sign ) + 1440 ) % 1440
            local newTime = timeFmt(newTimeMinutes)
            item.rename('Alarm set for ' .. newTime)
            dz.data.alarmTime = newTimeMinutes
Dutchsea
Re: Time widget
Post by Dutchsea »
Thanks, I also got this working after I removed the double quote at the start of the code.
I am just curious now; did you already create this code before or has it been made based on my specifc request?
Dutchsea
Re: Time widget
Post by Dutchsea »
Also, how can I get the alarm time to be used as input for another (your) script that triggers the alarm actions?
I need the value of local variable 'newTime' to be used as input for the script "Alarm Clock".
I can't use .devices(idx).name as this name includes text (e.g. "Alarm set for 9:00") while the Alarm Clock scripts requires a time.
Should I create another Dummy that gets as input the value 'newTime' and use that Dummy as input (local alarmTime = ) for the Alarm Clock Script?
Re: Time widget
Dutchsea wrote: Monday 02 November 2020 19:22 I am just curious now; did you already create this code before or has it been made based on my specifc request?
I wrote it because I wanted to find out if it could be a working and useful mechanism. So yes it was created triggered by your request. :D
Re: Time widget
Dutchsea wrote: Monday 02 November 2020 21:05 Also, how can I get the alarm time to be used as input for another (your) script that triggers the alarm actions?
If you show me your script I will adjust it to use the selector. (using a similar mechanism as now in the set time script)
Dutchsea
Re: Time widget
Post by Dutchsea »
waaren wrote: Monday 02 November 2020 21:22 I wrote it because I wanted to find out if it could be a working and useful mechanism. So yes it was created triggered by your request. :D
Nice! Special thanks!
Dutchsea
Re: Time widget
Post by Dutchsea »
waaren wrote: Monday 02 November 2020 21:26 If you show me your script I will adjust it to use the selector. (using a similar mechanism as now in the set time script)
Here you go:
-- Alarm clock [ dzVents >= 2.4 ]
scriptVar = '20191030 Alarmclock'
return
{ active = true,
    on =
        timer = { 'every hour' },    -- hourly run once to pick up target time
        httpResponses = { scriptVar }, -- Trigger the handle Json part
    logging = { level = domoticz.LOG_DEBUG },
        local alarmTime = dz.devices('Wekker').levelName
        -- dz.log('Alarm time name is: ' .. dz.devices(145).name, dz.LOG_DEBUG) -- Name alarm time device with idx 145
        if alarmTime ~= 'Off' then
            local minutesIn24Hours = 24 * 60
            local now = dz.time                             -- Get current time into time object
            local Time = require('Time')
            local targetTime = Time(dz.time.rawDate .. ' '  .. alarmTime .. ':00') -- Create target time object
            local function triggerAlarm(delay)
                local message = 'tring, trrring, trrring alarmclock ringing now. Was set on '.. dz.time.rawDate .. ', at ' .. dz.time.rawTime
                local url = dz.settings['Domoticz url'] .. "/json.htm?type=command&param=addlogmessage&message=" .. dz.utils.urlEncode(message)
                dz.openURL({ url = url, callback = scriptVar }).afterMin(math.floor(delay))
            if not(item.isHTTPResponse) then
                dz.log('Alarm time is set at : ' .. alarmTime)
                local deltaMinutes = math.floor(now.compare(targetTime).minutes)
                if now.compare(targetTime).compare < 1 then -- targetTime is in future
                    deltaMinutes = minutesIn24Hours - deltaMinutes
                dz.log('Alarmactions will be triggered in ' .. deltaMinutes .. ' minutes' ,dz.LOG_DEBUG)
                triggerAlarm(deltaMinutes)
                -- do wakeup actions.. here
                dz.log('wake up actions here....'  ,dz.LOG_INFO)
            	dz.devices('Kachel badkamer').switchOn()
                dz.devices('Kachel badkamer').switchOff().afterMin(15)
                dz.openURL('http://192.xxx.xxx.xxx:5005/Slaapkamer/volume/10')
            	dz.openURL('http://192.xxx.xxx.xxx:5005/Slaapkamer/unmute')
                dz.openURL('http://192.xxx.xxx.xxx:5005/Slaapkamer/favorite/ClassicFM')
            	dz.scenes('Awaken').switchOn()
Re: Time widget
Dutchsea wrote: Monday 02 November 2020 22:11
I sent you a PM
