[Solved] Need some help with a script  [Solved]
darkdude
Domoticz version: Release
Post by darkdude »
I need some help in finding a mistake in this script:
return
    on =
        devices =
            "Bufor - GÓRA",
    data =
        count =
            initial = 0,
        temp =
            initial = 0,
     logging =
        level = domoticz.LOG_DEBUG,
        marker = 'nagrzewaniePiecem',
   execute = function(domoticz)
       if domoticz.data.count == 0 then
            domoticz.data.temp = domoticz.devices("Bufor - GÓRA").temperature
            domoticz.data.count = domoticz.data.count + 1
            domoticz.notify('0')
       elseif domoticz.data.count > 0 and domoticz.data.count < 2 then
           domoticz.notify('1')
       elseif domoticz.data.count == 2 then
           local ratio = domoticz.devices("Bufor - GÓRA").temperature - domoticz.data.temp
           domoticz.notify('2')
           if ratio > 0.3 and ratio < 5 then
               domoticz.variables("nagrzewanie_piecem").set(1)
               domoticz.variables("nagrzewanie_piecem").set(0)
           domoticz.data.count = 0
It's purpose is to determine if a gas heater is working, based on differences in temperature readings. A sensor is updated every 10 seconds and the script is called. On first run it should put a reading into temperature variable. On second run it should only increase run counter. On the third run it should cmpare past reading to present one, change a variable and reset run counter.
It runs OK, does not report any errors but for some reason noting printed to log apart from information about script being processed. And variable is not updated.
Regards,
darkdude
Re: Need some help with a script
Post by darkdude »
I don't know what the initial problem was, but... at some point the counter passed 2 (which should never happen) and continued up to infinity :) Adding a line which reinitialized it after passing 2 solved the case.
