Adding your own cert
Posted: Wednesday 28 October 2020 1:39
My Asus router has the ability to setup DDNS along with a domain name, it's own cert via LetsEncrypt that renews and which all seems to work over https port 443.
If I turn on port forwarding I end up at my Domoticz install although it appears offline if I'm outside my own network but I think that's an auth issue.
Anyway I can export the cert from the router which gives me a cert.pem and a key.pem, how do I go about installing the cert.pem into my domoticz install?. I've read though the wiki page here https://www.domoticz.com/wiki/Native_se ... ts_Encrypt even the "Add the certificate to Domoticz" but to be honest it baffles me as it talks about installing, creating etc. and none of the paths match
Is there a folder I just to copy it into and if/when I do get it working is it a one off or do I keep needing to export it from my router into Domoticz as it renews? It says it expires Jan '21
