Adding your own cert
Calzor Suzay
Domoticz version: 4.9700
Post by Calzor Suzay »
My Asus router has the ability to setup DDNS along with a domain name, it's own cert via LetsEncrypt that renews and which all seems to work over https port 443.
If I turn on port forwarding I end up at my Domoticz install although it appears offline if I'm outside my own network but I think that's an auth issue.
Anyway I can export the cert from the router which gives me a cert.pem and a key.pem, how do I go about installing the cert.pem into my domoticz install?. I've read though the wiki page here https://www.domoticz.com/wiki/Native_se ... ts_Encrypt even the "Add the certificate to Domoticz" but to be honest it baffles me as it talks about installing, creating etc. and none of the paths match :?
Is there a folder I just to copy it into and if/when I do get it working is it a one off or do I keep needing to export it from my router into Domoticz as it renews? It says it expires Jan '21
Justintime
Re: Adding your own cert
Post by Justintime »
I was wondering the same. My guess is you have an Asus Router.
I just cant get Nginx or Apache reverse proxy to work. Been busy with it for several evenings.
It surprises me that there isnt a good tutorial on this for noobs especially while security is a big thing.
erem
Domoticz version: 2021.1
Post by erem »
@Justintime
you can try this tutorial, simple and to the point.
https://phoenixnap.com/kb/nginx-reverse-proxy
then the config should be something like this
server {
listen 60443;
location / {
proxy_pass http://domoticz_server_ip:8080;
then in your router forward port 60443 to the ip of your server running nginx
Regards,
Rob
