No device for temperature on Eurotronic spiritz thermostat
Posted: Tuesday 27 October 2020 18:55
by tlansbergen
Hi there,
I've added a Eurotronics Spritz z-wave thermostat. From the ozw panel I can see the thermostat reports the actual temperature. However domoticz created a lot of devices temperature is not one of them.
Is there a way to get a device for the temperature?
- OZW Panel
- spirit.JPG (56.16 KiB) Viewed 1045 times
Re: No device for temperature on Eurotronic spiritz thermostat
Posted: Tuesday 27 October 2020 19:04
by EddyG
What Domoticz version and ZWave version are you on, because I have another screen.
Currently I have 10 devices created.
Posted: Tuesday 27 October 2020 19:50
by Maxx
I have 3 eurotronics, the temperature device looks as follows:
4961 Zwave netwerk 0E01 1 TK_Eetkamer_Temp Temp LaCrosse TX3 20.1 C
Posted: Tuesday 27 October 2020 20:06
by tlansbergen
Hi Maxx, that is what I expect to see. Was this device added automatically or did you add it some other way?
Posted: Tuesday 27 October 2020 20:21
by Maxx
It was added automatically,
I am running one of the latest beta's of domoticz. What version are you using?
Posted: Wednesday 28 October 2020 9:29
by EddyG
All Zwave devices should be auto-created by Domoticz. How else should the Zwave system know which device to update.
It might take some time for every device to be created, even up to a day.
On beta version 12501 it should look like this.
- 2020-10-28_09-31-56.png (27.15 KiB) Viewed 1019 times
But the best way to help you is by knowing which version you are using.
Posted: Wednesday 28 October 2020 19:34
by tlansbergen
EddyG wrote: Wednesday 28 October 2020 9:29
You were right, eventually the temperature device showed up. Probably triggered by a change of temperature large enough to sent a message out.
Posted: Wednesday 28 October 2020 19:54
by Maxx
Another question since you both use the eurotronic. How long do your batteries last. Mine about 6 weeks in the wintertime. I have a zigbee version wich lasts 5 months.
Posted: Thursday 29 October 2020 9:14
by EddyG
I really do not count month, but at least 6 month to close to a year.
I open and close some of those valves 2 times a day automatically and sometimes 1 or 2 times a day manually.
They are open and regulating the valve during 4 hours.
During summertime they always open on 28 degrees C. because the heating is off.
You can check the device Level and see how often and how much "Set level" is changed, that is an indication for how often the motor is actuated.
Posted: Thursday 29 October 2020 15:46
by harrykausl
@transbergen : I had to reboot, then the device was visible.
@EddyG : In summertime or when my window sensor detects open window I set the heating mode of the Spiritz to off.
Posted: Friday 30 October 2020 9:50
by EddyG
In summertime I open the thermostat only for technical reason.
My pump starts every week (random) for a short period to keep it from getting stuck, so I open the thermostats permanently to get the flow also thru the radiators.
