Thermostat heatit z-temp2 not showing correctly
Posted: Tuesday 27 October 2020 9:30
by jithurbide
I try to figure out what's going on. I create config file for this device on openzwave. On the zwave console everything is working as expected. But on domoticz I have some issues.
First, I can't change the mode of the thermostat. You can check the utility page I have :
thermostat mode
thermostat mode
I can only change the mode by editing manually like :
thermostat mode edit
Second, I can't see the stat of the thermostat on normal mode. See image bellow :
thermostat stat
thermostat stat
But I see it on the device list.
Can somebody help me solve my issue ?
Best regards,
Julien Ithurbide
Posted: Tuesday 23 February 2021 13:08
by sbjbjoer
I have 4 heatit z-temp2 and z-water controller have not solved to get system work in domoticz nevest beta 2020.2 built 12976 zwater makes 10 instance switches and 4 airtemp instance
Not all switches responds to comands get timout from controller node
Thermostats get included 3 itemes setpoint .operate state. And mode
Therpostat only comunicated during include after included no new comminication registred in log ewen when try set point on thermostat no changes same not able to change setpount . Or mode in domoticz
Any got this heatit z-temp2 battery operated to work
Re: Thermostat heatit z-temp2 not showing correctly
Posted: Friday 01 October 2021 9:59
by Fred78
Hi everyone,
any news about this issue (that, by the way, seems to be more an Openzwave issue than a domoticz issue) ?
I'd like to buy a Heatit z-temp2 to replace my Danfoss, but I can't find any information about the fact that this device is now supported or not.
Posted: Sunday 06 February 2022 19:16
by Hellrazr
has anyone been able to get the Heatit Temp2 to work with domoticz?
Posted: Monday 07 February 2022 9:18
by Hellrazr
I replaced the heatit204.xml in the /home/pi/domoticz/Config/thermofloor directory with the one attached.
Seems to be working now.
Currently running Domoticz 2022.1 (build 14127)
heatit204.zip
heatit204.xml
(2.71 KiB) Downloaded 71 times
