Z-wave device switches off immediately after switching it on
Posted: Monday 26 October 2020 19:53
by JeroenL
Dear all,
Funny problem, I do not manage to debug at all.
What happens is the following, if a user or a timer switches on my Kitchen light, it immediately switches off again. Each time within 4 seconds. My suspicion was a faulty script, but disabling all scripts does not make the issue go away.
Has anyone else seen this? Does anyone have an idea, how I can "debug" this?
Thanks. Jeroen
Screenshot 2020-10-26 at 19.50.59.png (246.71 KiB) Viewed 1190 times
Re: Z-wave device switches off immediately after switching it on
Posted: Saturday 07 November 2020 17:25
by Keesje
hi Jeroen,
I'm experiencing exactly the same issue. PowerPlugs switching on after switches off within 5 seconds or vice versa.
First, I thought it was a bug in my (very simple) script but it also happens when manually switching the switch.
I have restarted Domoticz and it appeared to be solved but it occurs again a few days later.
Did you found the source already? Anybody else any ideas?
Thanks in advane,
Kees
Posted: Saturday 28 November 2020 12:48
by JeroenL
Dear Kees,
‘Happy’ to read someone else has the same issue. I had indeed also the same when using the physical switch.
I tried many things nothing seemed to work. I compared all setting of the zwave node, but they are the same as other similar working switches.
In the end I used a ‘rigorous’ solution, excluding and including the device again as a new node. This “fixed” it, but not in a nice way.
Am not a zwave expert, but I suspect something went wrong with the group functions. Meaning the device became part of some sort of group, whatcha switches it off again.
Hope re-including also works for you.
Regards jeroen
Posted: Friday 11 December 2020 13:06
by smartel
Hello Guys,
I have this weird issue on one of my Zwave switch, it does the same thing as yours. This problem started when I wrote a lua script to turn on/off with a motion detector.
That same script is working for many other switches, I have tried to disable all scripts, rebooted Domoticz, tried the exclusion/incluson trick, still does it.
I have to turn on the switch twice before it stays on, same thing to turn it off!
Any ideas?
Posted: Monday 21 December 2020 22:56
by smartel
Very strange, another one of my Zwave switch have started acting up the same way, I have to issue the On command twice before it stays on, same thing to turn it off, the log shows On-Off within the same second. Nothing has changed!
Any pointers are welcome, don’t know what to try anymore.
Thank you!
Posted: Tuesday 22 December 2020 10:11
by lost
Experienced the exact same behavior, from the very beginning & for only one device in my setup: A qubino smart-meter. This device primary function is monitoring my house electric power consumption, but also includes an internal solid state relay I use for the command of my hot water tank.
This internal relay shows same behavior. After a 1st switch to on, it goes off within 1 second for 99% of tries. If I retry just after (but not too long, less than 5s), required state remains stable at 99%.
Only way to handle this was reproducing what I was doing manually, with the timings that proved to mostly work, from a device script:
~/domoticz/scripts/lua $ cat script_device_SmartMeterHack.lua
-- Duplicate user Smart-Meter relay switch command after a few
-- seconds to cope with immediate spurious invalidating command on
-- device state change...
-- For hereunder tunables, take care not to set duplicate < spurious
-- to avoid making a switching loop + short duplicate times lead to
-- several retries (<= 3s).
-- A (string) user variable timeSmartMeterRelay must be created to 'nil'
-- before copying this script under domoticz/scripts/lua
-- Changelog:
--   20/04/2017, YL, 1st version.
spuriousCmdDelaySec=1
timeDuplicateCmdSec='5'
SmartMeterSwitch='Relais Smart-Meter HP/HC Actif'
timeLastCmd='timeSmartMeterRelay'
if (devicechanged[SmartMeterSwitch]) then
    devState = devicechanged[SmartMeterSwitch]
    t1 = os.time()
    t0 = uservariables[timeLastCmd]
    -- 1st time init for user variable...
    if (t0 == 'nil') then
        t0 = t1
    tDiff = os.difftime(t1, t0)
    -- Debug :
    --print(SmartMeterSwitch..' = '..devState)
    --print('t1 : '..t1..' / t0 : '..t0.. ' ; Diff = '..tDiff)
    -- Do we have the immediate change state spurious (buggy device?) invalidating current command ?
    if (tDiff <= spuriousCmdDelaySec) then
        if (devState == 'On') then
            commandArray[SmartMeterSwitch] = 'Off AFTER '..timeDuplicateCmdSec
        if (devState == 'Off') then
            commandArray[SmartMeterSwitch] = 'On AFTER '..timeDuplicateCmdSec
    commandArray['Variable:'..timeLastCmd] = tostring(t1)
I sent a ticket to qubino at the time, their answer was device was reporting it's change state with some delay that was a bit longer than what Open-Zwave expected... and they did an open-zwave ticket that never triggered a fix before I gave up expecting one!
Hope this helps... Take care to tune delays to the one that works for your device & change SmartMeterSwitch to your own switch name. As written, a user variable must also be created manually to record previous switch time & only send back command in case of almost immediate state change.
If this was a device I could have an easy alternative I would have sent it back to seller. But this is not the case for this module!
Posted: Monday 28 December 2020 1:47
by smartel
Thank you!
It’s a great ‘fix’ I will give that a try, I took those switches out of service, but they’re expensive, I’d rather use them!
I will try and post back results
