Dear all,
Funny problem, I do not manage to debug at all.
What happens is the following, if a user or a timer switches on my Kitchen light, it immediately switches off again. Each time within 4 seconds. My suspicion was a faulty script, but disabling all scripts does not make the issue go away.
Has anyone else seen this? Does anyone have an idea, how I can "debug" this?
Thanks. Jeroen
Z-wave device switches off immediately after switching it on
- Domoticz version: 2020.2
Re: Z-wave device switches off immediately after switching it on
hi Jeroen,
I'm experiencing exactly the same issue. PowerPlugs switching on after switches off within 5 seconds or vice versa.
First, I thought it was a bug in my (very simple) script but it also happens when manually switching the switch.
I have restarted Domoticz and it appeared to be solved but it occurs again a few days later.
Did you found the source already? Anybody else any ideas?
Thanks in advane,
Kees
Thanks in advane,
Kees
- Domoticz version: 2023.2
Dear Kees,
‘Happy’ to read someone else has the same issue. I had indeed also the same when using the physical switch.
I tried many things nothing seemed to work. I compared all setting of the zwave node, but they are the same as other similar working switches.
In the end I used a ‘rigorous’ solution, excluding and including the device again as a new node. This “fixed” it, but not in a nice way.
Am not a zwave expert, but I suspect something went wrong with the group functions. Meaning the device became part of some sort of group, whatcha switches it off again.
Hope re-including also works for you.
Regards jeroen
Regards jeroen
Hello Guys,
I have this weird issue on one of my Zwave switch, it does the same thing as yours. This problem started when I wrote a lua script to turn on/off with a motion detector.
That same script is working for many other switches, I have tried to disable all scripts, rebooted Domoticz, tried the exclusion/incluson trick, still does it.
I have to turn on the switch twice before it stays on, same thing to turn it off!
Any ideas?
Any ideas?
Very strange, another one of my Zwave switch have started acting up the same way, I have to issue the On command twice before it stays on, same thing to turn it off, the log shows On-Off within the same second. Nothing has changed!
Any pointers are welcome, don’t know what to try anymore.
Thank you!
Thank you!
Experienced the exact same behavior, from the very beginning & for only one device in my setup: A qubino smart-meter. This device primary function is monitoring my house electric power consumption, but also includes an internal solid state relay I use for the command of my hot water tank.
This internal relay shows same behavior. After a 1st switch to on, it goes off within 1 second for 99% of tries. If I retry just after (but not too long, less than 5s), required state remains stable at 99%.
Only way to handle this was reproducing what I was doing manually, with the timings that proved to mostly work, from a device script:
~/domoticz/scripts/lua $ cat script_device_SmartMeterHack.lua
I sent a ticket to qubino at the time, their answer was device was reporting it's change state with some delay that was a bit longer than what Open-Zwave expected... and they did an open-zwave ticket that never triggered a fix before I gave up expecting one!
Hope this helps... Take care to tune delays to the one that works for your device & change SmartMeterSwitch to your own switch name. As written, a user variable must also be created manually to record previous switch time & only send back command in case of almost immediate state change.
If this was a device I could have an easy alternative I would have sent it back to seller. But this is not the case for this module!
-- Duplicate user Smart-Meter relay switch command after a few
-- seconds to cope with immediate spurious invalidating command on
-- device state change...
-- For hereunder tunables, take care not to set duplicate < spurious
-- to avoid making a switching loop + short duplicate times lead to
-- several retries (<= 3s).
-- A (string) user variable timeSmartMeterRelay must be created to 'nil'
-- before copying this script under domoticz/scripts/lua
-- Changelog:
-- 20/04/2017, YL, 1st version.
spuriousCmdDelaySec=1
timeDuplicateCmdSec='5'
SmartMeterSwitch='Relais Smart-Meter HP/HC Actif'
timeLastCmd='timeSmartMeterRelay'
if (devicechanged[SmartMeterSwitch]) then
devState = devicechanged[SmartMeterSwitch]
t1 = os.time()
t0 = uservariables[timeLastCmd]
-- 1st time init for user variable...
if (t0 == 'nil') then
t0 = t1
tDiff = os.difftime(t1, t0)
-- Debug :
--print(SmartMeterSwitch..' = '..devState)
--print('t1 : '..t1..' / t0 : '..t0.. ' ; Diff = '..tDiff)
-- Do we have the immediate change state spurious (buggy device?) invalidating current command ?
if (tDiff <= spuriousCmdDelaySec) then
if (devState == 'On') then
commandArray[SmartMeterSwitch] = 'Off AFTER '..timeDuplicateCmdSec
if (devState == 'Off') then
commandArray[SmartMeterSwitch] = 'On AFTER '..timeDuplicateCmdSec
commandArray['Variable:'..timeLastCmd] = tostring(t1)
Thank you!
It’s a great ‘fix’ I will give that a try, I took those switches out of service, but they’re expensive, I’d rather use them!
I will try and post back results
