monitor the switch on time
Posted: Monday 26 October 2020 13:10
by Johan1974
Is it possible with Dzvents to display the switch on time in a counter? (Seconds or Minutes)
For example: switch name = 'Woonkamer' and Counter name = 'Tijd_aan’
Re: monitor the switch on time
Posted: Monday 26 October 2020 22:00
by Johan1974
It's working but the real time does not match with the displayed time. The displayed time is faster then the real time.
Would it be possible to make this in DZvents instead of LUA?
Posted: Monday 26 October 2020 22:16
by waaren
Johan1974 wrote: Monday 26 October 2020 22:00
Sure it's possible but what is the granularity you need? Does it need to be accurate on the second and should the counting sensor be updated every minute or is it enough to update the counter when "Woonkamer" is switched off?
Posted: Monday 26 October 2020 22:34
by Johan1974
It would be nice if the time is accurate to the second, but updated when the device turns off no problem.
Posted: Tuesday 27 October 2020 0:32
by waaren
Did you save it as a time triggered Lua script?
Posted: Tuesday 27 October 2020 1:34
by waaren
Johan1974 wrote: Monday 26 October 2020 22:34
Can you try below script?
dzVents script to keep track of active device time
local scriptVar = 'Woonkamer' -- must be a switch- or light type of device.
return
on =
devices =
scriptVar,
timer =
'at *:29', -- twice / hour to update timer when device is on for a longer period.
'at *:59',
data =
[scriptVar] =
initial =
['active'] = false,
['lastSet'] = os.time(),
logging =
level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all OK
marker = 'timeKeeper for ' .. scriptVar,
execute = function(dz, item)
local deltaSeconds = os.time() - dz.data[scriptVar].lastSet
local myCounter = dz.devices('Tijd_aan') -- define as counter and set to type: Counter, value Quantity: time, value Units: seconds
if item.isDevice and item.active and not(dz.data[scriptVar].active) then
dz.data[scriptVar].active = true
dz.data[scriptVar].lastSet = os.time()
dz.log('Counting seconds started', dz.LOG_DEBUG)
elseif item.isDevice and dz.data[scriptVar].active and not(item.active) then
dz.data[scriptVar].active = false
dz.log(item.name .. ' has been active for ' .. deltaSeconds .. ' seconds ', dz.LOG_DEBUG)
myCounter.updateCounter(myCounter.counter + deltaSeconds)
elseif item.isTimer and dz.data[scriptVar].active then
dz.log('Updating the counter', dz.LOG_DEBUG)
dz.log('No action needed', dz.LOG_DEBUG)
Posted: Tuesday 27 October 2020 15:37
by Johan1974
This works perfectly. One more little question, is it possible to count in seconds, and display in minutes.?
Posted: Tuesday 27 October 2020 17:07
by waaren
Johan1974 wrote: Tuesday 27 October 2020 15:37
Yes but you will loose some accuracy..
change
to
myCounter.updateCounter(dz.utils.round( ( myCounter.counter * 60 + deltaSeconds ) / 60 , 1 ) )
at lines 52 and 56
Posted: Tuesday 27 October 2020 18:24
by Johan1974
When the 'Living room' switch is on for 2 x 40 seconds (On off on), the counter should be at 1 minute. The counter will reset to 0 if it has not reached 60 seconds.??
Posted: Tuesday 27 October 2020 20:01
by waaren
Johan1974 wrote: Tuesday 27 October 2020 18:24
No what i meant with loosing accuracy was this:
because of the round function the first time is will be 40/60 = 0.66667 ==> 0.7 minutes and the next time
( 0.7 * 60 + 40 ) / 60 ==> 1.36666 = 1.4
in seconds it would have been 80 / 60 = 1.3333 = 1.3
NB. If you start again and use the same counter you will not see the expected outcome. So better "start fresh"
Posted: Wednesday 28 October 2020 9:12
by waaren
Had another look at it and below version limits the loss of accuracy by keeping track of the total number of seconds in the background.
History:
20201026: Start coding
20201027: Add timer section to update when device is active for a longer period
20201027: Changed updating counter to minutes
20201028: Add keeping track of total seconds to improve accuracy
return
on =
devices =
scriptVar,
timer =
'at *:59',
data =
[scriptVar] =
initial =
['active'] = false,
['activeAt'] = os.time(),
['total'] = 0,
logging =
local deltaSeconds = os.time() - dz.data[scriptVar].activeAt
local myCounter = dz.devices('teller2') -- define as counter and set to type: Counter, value Quantity: time, value Units: seconds
local function managedUpdate(myCounter, deltaSeconds)
if dz.data[scriptVar].total == nil or dz.data[scriptVar].total == 0 then
dz.data[scriptVar].total = myCounter.counter * 60 + deltaSeconds
dz.data[scriptVar].total = dz.data[scriptVar].total + deltaSeconds
local newTotal = dz.utils.round( ( dz.data[scriptVar].total / 60 ), 1 )
myCounter.updateCounter(newTotal)
return newTotal
dz.data[scriptVar].activeAt = os.time()
dz.log(item.name .. ' has been active for ' .. deltaSeconds .. ' seconds since last update.', dz.LOG_DEBUG)
local activeTotalMinutes = managedUpdate(myCounter, deltaSeconds)
dz.log('Overall active time for ' .. item.name .. ' is ' .. activeTotalMinutes .. ' minutes.', dz.LOG_DEBUG)
dz.log('Updated the counter to ' .. activeTotalMinutes .. ' minutes', dz.LOG_DEBUG)
Re: monitor the switch on time [Solved]
Posted: Thursday 29 October 2020 11:41
by Johan1974
Thank you very much.!
The script is already running here ..
