How to set timer - need to have active two sensors in specific time.
Posted: Wednesday 21 October 2020 20:24
by nowy
Hi All,
I need dzvents script that will activate the switch if at least two any motion sensors (from 10 sensors) are active simultaneously in last 5 minutes.
So if first sensor detects the move then timer starts and if in the next 5 minutes second sensor discovers move then switch will be activated.
To be honest I didn't find option in doc how to achive it.
Re: How to set timer - need to have active two sensors in specific time.
Posted: Wednesday 21 October 2020 22:00
by waaren
nowy wrote: Wednesday 21 October 2020 20:24 To be honest I didn't find option in doc how to achieve it.
The wiki cannot give a dzVents solution for all automation challenges. It provides a description of the framework , methods and attributes you can use to create scripts up to your task.
Something like below should get you started.
-- 2 out of 10
local sensors =           -- table with names of all your motion sensors
    'motion Sensor1',
    'motion Sensor2',
    'motion Sensor3',
    'motion Sensor4',
    'motion Sensor5',
    'motion Sensor6',
    'motion Sensor7',
    'motion Sensor8',
    'motion Sensor9',
    'motion Sensor10',
local theSwitch = 'the switch' -- change to name of your switch
return
    on =
        devices = sensors,
    data =
        motionSensors =
            initial = {},
    logging =
        level = domoticz.LOG_DEBUG, -- change to domoticz.LOG_ERROR when all OK
        marker = 'scene Control',
    execute = function(dz, item)
        local function saveSensorActivationTime(str)
            dz.data.motionSensors[str] = os.time()
        local function twoOutOfTen()
            local active = 0
            for _, sensorName in ipairs(sensors) do
                local seconds = os.time() -(  dz.data.motionSensors[sensorName] or 0 )
                if seconds < 300  then
                    dz.log(sensorName .. ' was activated ' .. seconds .. ' seconds ago.', dz.LOG_DEBUG )
                    active = active + 1
                    if active > 1 then return true end
        if item.active then
            saveSensorActivationTime(item.name)
            if twoOutOfTen() then
                 dz.devices(theSwitch).switchOn()
Posted: Wednesday 21 October 2020 23:18
by nowy
Where should I place additional condition like if domoticz.devices('Alarm').state == 'On') then execute rest function so turn on the switch if at least these two sensors are active.
Posted: Wednesday 21 October 2020 23:37
by waaren
nowy wrote: Wednesday 21 October 2020 23:18 Where should I place additional condition like if domoticz.devices('Alarm').state == 'On') then execute rest function so turn on the switch if at least these two sensors are active.
There are multiple approaches to that but to keep it simple change
to
if twoOutOfTen() and dz.devices('Alarm').state == 'On'  then
Posted: Thursday 22 October 2020 0:20
by nowy
Tested and ...
Script works well when I added two tested switches and manually activated them but when I use my motion sensors scripts starts and right away finish. What can be wrong?
2020-10-22 00:15:14.624 Status: dzVents: Info: XXX: ------ Start internal script: Test: Device: "Garaż (Dummy)", Index: 135
2020-10-22 00:15:14.626 Status: dzVents: Info: XXX: ------ Finished Test
Here is current script I have
    'Salon',
    'Garaż',
    'Kuchnia',
local theSwitch = 'Włamanie noc' -- change to name of your switch
return
    on =
        devices = sensors,
    data =
        motionSensors =
            initial = {},
    logging =
        marker = 'XXX',
            local active = 0
                    active = active + 1
        if item.active then
            if twoOutOfTen()  and dz.devices('Alarm noc').state == 'On'  then
Posted: Thursday 22 October 2020 7:01
by waaren
nowy wrote: Thursday 22 October 2020 0:20 Tested and ...
It seems that your motion sensors do not report that they are active or your Alarm does not report it has the 'On' state.
If a script does not work as expected and the log does not show sufficient information to understand why, a first step to find a possible cause is to add more (debug)log statements... I added some in below script.
    'Salon',
    'Garaż',
    'Kuchnia',
local myAlarm = 'Alarm noc' -- change to name of your alarm
return
    on =
        devices = sensors,
    data =
        motionSensors =
            initial = {},
    logging =
        local alarm = dz.devices(myAlarm)
        local switch = dz.devices(theSwitch)
            dz.log('os.time() is now: ' .. os.time(), dz.LOG_DEBUG )
            if  _G.logLevel == dz.LOG_DEBUG then
                dz.utils.dumpTable(dz.data) -- show the content of persistent data
            local active = 0
                if dz.data.motionSensors[sensorName] ~= nil then
                    local seconds = os.time() -  dz.data.motionSensors[sensorName]
                        active = active + 1
            return active > 1
        dz.log(item.name .. ' state: ' .. tostring(item.state) .. '; active state: ' .. tostring(item.active), dz.LOG_DEBUG)
        if item.active then
            dz.log(alarm.name .. ' state: ' .. tostring(alarm.state), dz.LOG_DEBUG)
            if twoOutOfTen() and alarm.state == 'On' then
                 dz.log('Switch ' .. switch.name .. ' will be activated',dz.LOG_DEBUG)
                 switch.switchOn()
Posted: Thursday 22 October 2020 12:20
by nowy
Here you are logs:
2020-10-22 12:19:16.629 Status: dzVents: Info: scene Control: ------ Start internal script: Test: Device: "Garaż (Dummy)", Index: 135
2020-10-22 12:19:16.632 Status: dzVents: Debug: scene Control: Processing device-adapter for Alarm noc: Switch device adapter
2020-10-22 12:19:16.634 Status: dzVents: Debug: scene Control: Processing device-adapter for Włamanie noc: Switch device adapter
2020-10-22 12:19:16.634 Status: dzVents: Debug: scene Control: Garaż state: 21.70;48.64;1; active state: false
2020-10-22 12:19:16.635 Status: dzVents: Info: scene Control: ------ Finished Test
2020-10-22 12:19:21.935 Status: dzVents: Info: scene Control: ------ Start internal script: Test: Device: "Salon (Dummy)", Index: 183
2020-10-22 12:19:21.938 Status: dzVents: Debug: scene Control: Processing device-adapter for Alarm noc: Switch device adapter
2020-10-22 12:19:21.940 Status: dzVents: Debug: scene Control: Processing device-adapter for Włamanie noc: Switch device adapter
2020-10-22 12:19:21.940 Status: dzVents: Debug: scene Control: Salon state: 24.60;49.67;1; active state: false
2020-10-22 12:19:21.941 Status: dzVents: Info: scene Control: ------ Finished Test
2020-10-22 12:19:46.622 Status: dzVents: Info: scene Control: ------ Start internal script: Test: Device: "Garaż (Dummy)", Index: 135
2020-10-22 12:19:46.625 Status: dzVents: Debug: scene Control: Processing device-adapter for Alarm noc: Switch device adapter
2020-10-22 12:19:46.627 Status: dzVents: Debug: scene Control: Processing device-adapter for Włamanie noc: Switch device adapter
2020-10-22 12:19:46.627 Status: dzVents: Debug: scene Control: Garaż state: 21.63;48.62;1; active state: false
2020-10-22 12:19:46.628 Status: dzVents: Info: scene Control: ------ Finished Test
Re: How to set timer - need to have active two sensors in specific time.  [Solved]
Posted: Thursday 22 October 2020 13:10
by waaren
nowy wrote: Thursday 22 October 2020 12:20 Here you are logs:
It looks like the devices that you put in the sensors table are temperature / humidity devices. The script expect motion sensors...
can you use this modified script (with an extra logline to identify the deviceType and deviceSubType)
    'Salon',
    'Garaż',
    'Kuchnia',
return
    on =
        devices = sensors,
    data =
        motionSensors =
            initial = {},
    logging =
            local active = 0
                        active = active + 1
            return active > 1
        dz.log(item.name .. ' state: ' .. tostring(item.state) .. '; active state: ' .. tostring(item.active),  dz.LOG_DEBUG )
        dz.log(item.name .. ' (' .. item.idx ..');  deviceType: ' .. tostring(item.deviceType) .. '; deviceSubType: ' .. tostring(item.deviceSubType), dz.LOG_DEBUG )
        if item.active then
                 switch.switchOn()
Posted: Thursday 22 October 2020 14:21
by nowy
Sorry my fault I have also the temp+hum sensors behind the motion sensors - I disabled them to not confused log output.
Motion sensors are Light/Switch type (wireless 433MHz) with Sonoff RF Bridge.
2020-10-22 14:14:26.580 Status: dzVents: Info: scene Control: ------ Finished Test
2020-10-22 14:14:30.212 MQTT: Topic: domoticz/in, Message: {"idx":10,"nvalue":0,"svalue":"15621550","Battery":59,"RSSI":6}
2020-10-22 14:14:30.579 (Dummy) Light/Switch (Salon)
2020-10-22 14:14:30.539 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-10-22 14:14:31.368 MQTT: Topic: domoticz/in, Message: {"idx":59,"nvalue":0,"svalue":"15621550","Battery":57,"RSSI":9}
2020-10-22 14:14:39.083 MQTT: Topic: domoticz/in, Message: {"idx":10,"nvalue":0,"svalue":"15683422","Battery":59,"RSSI":6}
2020-10-22 14:14:39.206 MQTT: Topic: domoticz/in, Message: {"idx":59,"nvalue":0,"svalue":"15683422","Battery":57,"RSSI":9}
2020-10-22 14:14:43.750 MQTT: Topic: domoticz/in, Message: {"idx":10,"nvalue":0,"svalue":"7799975","Battery":59,"RSSI":6}
2020-10-22 14:14:44.522 MQTT: Topic: domoticz/in, Message: {"idx":59,"nvalue":0,"svalue":"15599950","Battery":57,"RSSI":9}
2020-10-22 14:14:50.174 MQTT: Topic: domoticz/in, Message: {"idx":10,"nvalue":0,"svalue":"15603710","Battery":60,"RSSI":6}
2020-10-22 14:14:51.431 MQTT: Topic: domoticz/in, Message: {"idx":10,"nvalue":0,"svalue":"15599950","Battery":59,"RSSI":6}
2020-10-22 14:14:51.556 MQTT: Topic: domoticz/in, Message: {"idx":59,"nvalue":0,"svalue":"15599950","Battery":57,"RSSI":9}
2020-10-22 14:14:57.082 MQTT: Topic: domoticz/in, Message: {"idx":59,"nvalue":0,"svalue":"15634430","Battery":57,"RSSI":9}
2020-10-22 14:14:57.205 MQTT: Topic: domoticz/in, Message: {"idx":10,"nvalue":0,"svalue":"15634430","Battery":59,"RSSI":7}
2020-10-22 14:15:04.637 MQTT: Topic: domoticz/in, Message: {"idx":10,"nvalue":0,"svalue":"14761994","Battery":59,"RSSI":5}
2020-10-22 14:15:04.961 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-10-22 14:15:05.012 (Dummy) Light/Switch (Drzwi garaż)
2020-10-22 14:15:06.238 MQTT: Topic: domoticz/in, Message: {"idx":59,"nvalue":0,"svalue":"15506830","Battery":57,"RSSI":9}
2020-10-22 14:15:06.581 (Dummy) Light/Switch (Garaż)
2020-10-22 14:15:06.560 Status: EventSystem: Script event triggered: /home/pi/domoticz/dzVents/runtime/dzVents.lua
2020-10-22 14:15:07.131 MQTT: Topic: domoticz/in, Message: {"idx":10,"nvalue":0,"svalue":"15506830","Battery":59,"RSSI":5}
2020-10-22 14:15:11.861 MQTT: Topic: domoticz/in, Message: {"idx":59,"nvalue":0,"svalue":"14761994","Battery":57,"RSSI":9}
2020-10-22 14:15:12.221 (Dummy) Light/Switch (Drzwi garaż)
2020-10-22 14:15:12.508 MQTT: Topic: domoticz/in, Message: {"idx":1
2020-10-22 14_19_03-Domoticz.png (95.75 KiB) Viewed 851 times
